[Geomoose-users] WFS Service
Nelson Soto NSoto at plotplans.com
Thu Feb 19 10:01:22 EST 2009
Hey Brian,
I realize this is beyond anything you support here but I had a question
in regards to the link below and WFS.
I am pretty sure I am forming my string correctly but for some reason
the WFS says the Type can not be found? I am more used to a
"servicename:layername" approach to specifying a feature request but
here I am assuming I use the ID?
http://www.datafinder.org/wfsconnector/com.esri.wfs.Esrimap/MN_MetroGIS_
DataFinder_WFS_Administrative_Political_Boundaries?SERVICE=wfs&VERSION=1
.0.0&REQUEST=getfeature&TYPENAME=county
I tried using the long entry in the <Name> tag as an alternative but
receive a different type of error.
I am only asking you because it seems like you have used these with some
form of success in the past? I'm pretty sure I am requesting an
incorrect TYPENAME but am having problems trying to figure out what tags
in the GetCapabilities I should use.
Any thoughts are welcome.
Thanks.
From: Fischer, Brian [mailto:bfischer at houstoneng.com]
Sent: Wednesday, February 18, 2009 11:01 AM
To: Nelson Soto; geomoose-users at lists.sourceforge.net
Subject: RE: [Geomoose-users] WFS Service
Here's a bunch for Minnesota.  I also had one of these WFS services
setup as a layer in the State or County GeoMOOSE demo.
http://www.datafinder.org/services/index.asp
Brian Fischer
Houston Engineering, Inc.
Maple Grove, MN
(763) 493-4522
Sent: Wednesday, February 18, 2009 8:51 AM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] WFS Service
Does anyone know of a either a list of WFS Services that are available
or an example WFS service I could use? The data is unimportant and isn't
necessarily related to GeoMoose; I just assumed the community may know
of some. I am trying to consume WFS data but would like to test against
data other than my own.
Thanks.
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20090219/b9784be5/attachment.html
More information about the Geomoose-users mailing list
