[Geomoose-users] Problem with Information Box with Lines and Pointshapefiles
Fischer, Brian bfischer at houstoneng.com
Tue Feb 24 12:02:58 EST 2009
The only thought that comes to mind is the tolerance setting.  Try
increasing it a little more.  Otherwise make sure your layer name is the
same as your map service in the .xml file.  Should work then.
Brian Fischer
Houston Engineering, Inc.
Maple Grove, MN
(763) 493-4522
From: Edward E. Boesenberg, III [mailto:eboesenberg at niraengineers.com]
Sent: Monday, February 23, 2009 4:00 PM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] Problem with Information Box with Lines and
Pointshapefiles
I am trying to populate the information box with info from point and
line shapefiles but it is not working.  I am able to get the Information
Box to work with polygons but not lines or points.  What could be wrong?
I attached my map file if it helps.
Ed
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20090224/adff6675/attachment.html
More information about the Geomoose-users mailing list
