[Geomoose-users] Problem with Information Box with Lines and Pointshapefiles
Heather Wirth HWIRTH at co.benton.mn.us
Tue Feb 24 12:08:07 EST 2009
The other thing I noticed, I know in previous versions the LAYER's NAME
could not have any spaces in it.  It used to be that the identify.map
file had this comment next to the Layer's Name: "Needs to match Mapbook,
spaces are removed."  That is how I have my file setup, and it works
fine for points and lines.  I don't know if this is still the case
though.  Good luck.
>>> "Fischer, Brian" <bfischer at houstoneng.com> 2/24/2009 11:02 AM >>>
The only thought that comes to mind is the tolerance setting.  Try
increasing it a little more.  Otherwise make sure your layer name is
the
same as your map service in the .xml file.  Should work then.
Brian Fischer
Houston Engineering, Inc.
Maple Grove, MN
(763) 493-4522
From: Edward E. Boesenberg, III [mailto:eboesenberg at niraengineers.com]
Sent: Monday, February 23, 2009 4:00 PM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] Problem with Information Box with Lines and
Pointshapefiles
I am trying to populate the information box with info from point and
line shapefiles but it is not working.  I am able to get the
Information
Box to work with polygons but not lines or points.  What could be
wrong?
I attached my map file if it helps.
Ed
More information about the Geomoose-users mailing list
