[Geomoose-users] Problem with Geomoose in Internet Explorer
Dan Little danlittle at yahoo.com
Tue Feb 24 13:49:07 EST 2009
Good news, both of your files seem to parse.
Bad news, that means I don't directly know why your map is not appearing.  My next theory is that it related to your reprojection code and/or whether the file exists for it.
If this is on a public server I could get more information since I have the IE debugger installed... short of that, do you see any listed errors in IE?
From: "Edward E. Boesenberg, III" <eboesenberg at niraengineers.com>
To: Dan Little <danlittle at yahoo.com>; geomoose-users at lists.sourceforge.net
Sent: Tuesday, February 24, 2009 12:34:45 PM
Subject: RE: [Geomoose-users] Problem with Geomoose in Internet Explorer
The mapbook file and the config file is attached.
I modified two things in the config file, the “Jump to” information and coordinate system.
I modified the list of layers in the xml file.
Sent: Tuesday, February 24, 2009 1:01 PM
To: Edward E. Boesenberg, III; geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] Problem with Geomoose in Internet Explorer
It could be any one of the following:
1) An error in the Mapbook.
2) An error in the config.js.
IE and FF use radically different parsers for both of these tasks and they differ in how forgiving they are.  If you can attach either the mapbook or the config.js then I/we can take a look to see where there may be an error.
From:"Edward E. Boesenberg, III" <eboesenberg at niraengineers.com>
To: geomoose-users at lists.sourceforge.net
Sent: Tuesday, February 24, 2009 11:58:38 AM
Subject: [Geomoose-users] Problem with Geomoose in Internet Explorer
My Geomoose setup works perfectly in Firefox but when I try to use it in Internet Explorer (IE) I get a blank map.  The County Demo works using IE but I started my Geomoose app by modifying the State Demo and now it doesn’t work in IE.
Any ideas?
Ed
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20090224/098e66de/attachment.html
More information about the Geomoose-users mailing list
