[Geomoose-users] Problem with Geomoose in Internet Explorer
Brent Fraser bfraser at geoanalytic.com
Tue Feb 24 15:45:53 EST 2009
Edward E. Boesenberg, III wrote:
> Geomoose doesn't display Lat / Long, only X / Y.
Since you've set:
  var MAP_COORDINATE_DISPLAY = {
	groundUnits : true,
	lonLat : true /* Will only display if MAP_COORDINATE_SYSTEM is set */
in your config file, GeoMoose either it can't find (or execute) your State Plane javascript.  did you follow all the instructions on the "Add Your Own Projection" How-To page?  Especially the part on re-compiling the GEoMOOSE.js file (I missed that when I added my Mercator projection).
> When I remove the line for MAP_COORDINATE_SYSTEM variable, Geomoose doesn't
> work at all.
Don't remove it, Use the MAP_COORDINATE_DISPLAY to enable/disable it.
So I'll ask again.  Does your modified GeoMoose setup work in Firefox and not Internet Explorer?
Brent
> -----Original Message-----
> From: Brent Fraser [mailto:bfraser at geoanalytic.com]
> Sent: Tuesday, February 24, 2009 3:24 PM
> To: Edward E. Boesenberg, III
> Cc: geomoose-users at lists.sourceforge.net
> Subject: Re: [Geomoose-users] Problem with Geomoose in Internet Explorer
>> All of my MAP files do not have a projection specified because they are
> all the same (State Plane - feet).  The values for the INITIAL-VIEW and
> JUMP-TO both reference feet.
> Good. More specifically, the coordinates in are State Plane PA-South (which
> implies feet).
>> I thought I needed MAP_COORDINATE_SYSTEM set correctly to display my map,
> so I don't need a reprojection file or need to set the MAP_COORDINATE_SYSTEM
> value
> No, it is only required for only for the lat/lon display on the web page
> footer.  See the first paragraph of
> http://www.geomoose.org/moose/index.php?option=com_content&task=view&id=22&I
> temid=28
> Does it work in Firefox?
> Brent
> Open Source Business Conference (OSBC), March 24-25, 2009, San Francisco, CA
> -OSBC tackles the biggest issue in open source: Open Sourcing the Enterprise
> -Strategies to boost innovation and cut costs with open source participation
> -Receive a $600 discount off the registration fee with the source code: SFAD
> http://p.sf.net/sfu/XcvMzF8H
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
