[Geomoose-users] Problem with Geomoose in Internet Explorer
Edward E. Boesenberg, III eboesenberg at niraengineers.com
Tue Feb 24 16:27:29 EST 2009
IE 7
-----Original Message-----
From: Brent Fraser [mailto:bfraser at geoanalytic.com]
Sent: Tuesday, February 24, 2009 4:05 PM
To: Edward E. Boesenberg, III
Cc: geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] Problem with Geomoose in Internet Explorer
Interesting.  Which version of IE are you using?  IE 6 has some problems
with transparent PNGs.
I notice from your screen shot none of the menu items or tools are loading.
Maybe Dan is on the right track about IE's unforgiving parser...
Brent
Edward E. Boesenberg, III wrote:
> My setup DOES NOT work in Internet Explorer, but it does work in Firefox.
> Sent: Tuesday, February 24, 2009 3:46 PM
>> Geomoose doesn't display Lat / Long, only X / Y.
> Since you've set:
>   var MAP_COORDINATE_DISPLAY = {
> 	groundUnits : true,
> 	lonLat : true /* Will only display if MAP_COORDINATE_SYSTEM is set
> in your config file, GeoMoose either it can't find (or execute) your State
> Plane javascript.  did you follow all the instructions on the "Add Your
Own
> Projection" How-To page?  Especially the part on re-compiling the
> GEoMOOSE.js file (I missed that when I added my Mercator projection).
>> When I remove the line for MAP_COORDINATE_SYSTEM variable, Geomoose
> doesn't
>> work at all.
> Don't remove it, Use the MAP_COORDINATE_DISPLAY to enable/disable it.
> So I'll ask again.  Does your modified GeoMoose setup work in Firefox and
> not Internet Explorer?
> Brent
>> Sent: Tuesday, February 24, 2009 3:24 PM
>>> All of my MAP files do not have a projection specified because they are
>> all the same (State Plane - feet).  The values for the INITIAL-VIEW and
>> JUMP-TO both reference feet.
>> Good. More specifically, the coordinates in are State Plane PA-South
> (which
>> implies feet).
>>> I thought I needed MAP_COORDINATE_SYSTEM set correctly to display my
map,
>> so I don't need a reprojection file or need to set the
>> value
>> No, it is only required for only for the lat/lon display on the web page
>> footer.  See the first paragraph of
http://www.geomoose.org/moose/index.php?option=com_content&task=view&id=22&I
>> temid=28
>> Does it work in Firefox?
>> Brent
>> Open Source Business Conference (OSBC), March 24-25, 2009, San Francisco,
> CA
>> -OSBC tackles the biggest issue in open source: Open Sourcing the
> Enterprise
>> -Strategies to boost innovation and cut costs with open source
> participation
>> -Receive a $600 discount off the registration fee with the source code:
> SFAD
>> http://p.sf.net/sfu/XcvMzF8H
>> Geomoose-users mailing list
>> Geomoose-users at lists.sourceforge.net
>> https://lists.sourceforge.net/lists/listinfo/geomoose-users
CA
Enterprise
participation
SFAD
Open Source Business Conference (OSBC), March 24-25, 2009, San Francisco, CA
-OSBC tackles the biggest issue in open source: Open Sourcing the Enterprise
-Strategies to boost innovation and cut costs with open source participation
-Receive a $600 discount off the registration fee with the source code: SFAD
More information about the Geomoose-users mailing list
