[Geomoose-users] Any plans to make View Extents a service?
Fischer, Brian bfischer at houstoneng.com
Tue Feb 24 22:20:22 EST 2009
Brent,
Loading the area of interest can be done on startup using URL
parameters.  It is the Jump-To lists that is going to be the problem.
Take a look at this page if you haven't found it already.
http://www.geomoose.org/moose/index.php?option=com_content&task=view&id=
17&Itemid=29 Specifically the zoomto parameter.
-Brian
-----Original Message-----
From: Brent Fraser [mailto:bfraser at geoanalytic.com]
Sent: Tuesday, February 24, 2009 4:53 PM
To: Jim Klassen
Cc: geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] Any plans to make View Extents a service?
Jim,
  I was thinking to load the user-specific data at page-load time to
solve my problem, but I can see where it would be useful to trigger a
service request for any GUI event.
  Just to clarify, I've got a 100 users each with a different Jump-To
list of around 10 to 100 Area-Of-Interest extents, and the extents list
will slowly change over time.
Thanks,
Brent Fraser
Jim Klassen wrote:
> This is something I've been pondering for awhile, but not enough to
get to any coding...
> The magic feature that I want that would make things like this easier
is allowing the services to configure themselves at runtime. I have a
couple of services where what is search-able changes over time based on
what is stored in a database. Thus, being able to pull the drop down
lists from the DB (via a server side service) would be easier to
maintain than fixed drop down lists in the mapbook (or config.js).
> Very rough idea...
> create a parameter in the mapbook to indicate that a service should
try to auto-config, possibly with the url of a document to get that
contains the necessary parameters... say XML or JSON.
> When the user selects the service/tool/whatever, GeoMOOSE makes a
quick AJAX/JSON call to the provided URL which responds with the
options/questions to present to the user.
> The user then makes the request as normal.
> Example: User clicks Zoom to Extents. GeoMOOSE asks which user you
would like extents for? The user responds and clicks submit and the
extents for that user come up as the result of a search tool. (BTW: you
can do this now if you write the server side service to implement the
search and hard code the user list into the mapbook.)
> (Even better would be if the drop downs and/or other fields could be
linked and change depending on what others are set to.)
>>>> Brent Fraser <bfraser at geoanalytic.com> 02/24/09 3:11 PM >>>
> Brian,
>   I'm trying to avoid the separate config files as there are about 100
users with 10 to 100 different areas each.  There's a database on the
server with lots of other user-specific map and attribute info I'll be
querying so I thought why not build an Extent service...
>   I'll have a look in the 1.2 version.
> Fischer, Brian wrote:
>> The funny thing is we had this as a part of the xml mapbook, but we
>> moved in into the config.js file in version 1.4 for performance
reasons.
>> When it was in the .xml file it caused the application to load slow
when
>> you have a big list of zoom to items.
>> Unfortunately I don't think there would be a way to configure GM 1.6
to
>> do this without hacking a bunch of code.  The only way I can think of
is
>> to store a separate config.js file for each of your users.
>> I will throw out that in GM 2.0 we are planning on moving that back
into
>> the .xml file and Dan's vision is to only have one configuration file
>> that is the XML map book.
> That's got my vote (as long as there's not sacrifice in performance).
> Thanks!
> Brent Fraser
> Open Source Business Conference (OSBC), March 24-25, 2009, San
Francisco, CA
> -OSBC tackles the biggest issue in open source: Open Sourcing the
Enterprise
> -Strategies to boost innovation and cut costs with open source
participation
> -Receive a $600 discount off the registration fee with the source
code: SFAD
> http://p.sf.net/sfu/XcvMzF8H
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
Francisco, CA
Enterprise
participation
-Receive a $600 discount off the registration fee with the source code:
SFAD
More information about the Geomoose-users mailing list
