[Geomoose-users] Problem with Geomoose in Internet Explorer
Edward E. Boesenberg, III eboesenberg at niraengineers.com
Wed Feb 25 12:18:51 EST 2009
Dan,
I just installed the debugger and tried my setup, of course I got an runtime
error. The debugger highlighted the text "parent.appendChild(loadingBar)" in
Geomoose.js.  The text is located near the bottom, 24 lines above the
functions for panning.
-----Original Message-----
Sent: Wednesday, February 25, 2009 11:42 AM
To: Edward E. Boesenberg, III; Brent Fraser
Cc: geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] Problem with Geomoose in Internet Explorer
Ed,
Do you have Firebug installed on Firefox? If so, can you try
disabling/suspending it and reloading the page in FF? Then check the Error
Console for any errors. Firebug graciously "fixes" some things that cause
bugs in standard Firefox and IE.
If you do not have firefox, can you double check that there are no errors in
the error console when you load GeoMOOSE? Firefox recovers much more
gracefully from errors than does IE.
----- Original Message ----
> From: "Edward E. Boesenberg, III" <eboesenberg at niraengineers.com>
> To: Brent Fraser <bfraser at geoanalytic.com>
> Sent: Tuesday, February 24, 2009 3:27:29 PM
> IE 7
> From: Brent Fraser [mailto:bfraser at geoanalytic.com]
> Sent: Tuesday, February 24, 2009 4:05 PM
> Interesting.  Which version of IE are you using?  IE 6 has some problems
> with transparent PNGs.
> I notice from your screen shot none of the menu items or tools are
loading.
> Maybe Dan is on the right track about IE's unforgiving parser...
> Brent
> Edward E. Boesenberg, III wrote:
> > My setup DOES NOT work in Internet Explorer, but it does work in
Firefox.
> > Sent: Tuesday, February 24, 2009 3:46 PM
> >> Geomoose doesn't display Lat / Long, only X / Y.
> > Since you've set:
> >   var MAP_COORDINATE_DISPLAY = {
> >     groundUnits : true,
> >     lonLat : true /* Will only display if MAP_COORDINATE_SYSTEM is set
> > in your config file, GeoMoose either it can't find (or execute) your
State
> > Plane javascript.  did you follow all the instructions on the "Add Your
> Own
> > Projection" How-To page?  Especially the part on re-compiling the
> > GEoMOOSE.js file (I missed that when I added my Mercator projection).
> >> When I remove the line for MAP_COORDINATE_SYSTEM variable, Geomoose
> > doesn't
> >> work at all.
> > Don't remove it, Use the MAP_COORDINATE_DISPLAY to enable/disable it.
> > So I'll ask again.  Does your modified GeoMoose setup work in Firefox
and
> > not Internet Explorer?
> > Brent
> >> Sent: Tuesday, February 24, 2009 3:24 PM
Explorer
> >>> All of my MAP files do not have a projection specified because they
are
> >> all the same (State Plane - feet).  The values for the INITIAL-VIEW and
> >> JUMP-TO both reference feet.
> >> Good. More specifically, the coordinates in are State Plane PA-South
> > (which
> >> implies feet).
> >>> I thought I needed MAP_COORDINATE_SYSTEM set correctly to display my
> map,
> >> so I don't need a reprojection file or need to set the
> >> value
> >> No, it is only required for only for the lat/lon display on the web
page
> >> footer.  See the first paragraph of
http://www.geomoose.org/moose/index.php?option=com_content&task=view&id=22&I
> >> temid=28
> >> Does it work in Firefox?
> >> Brent
> >> Open Source Business Conference (OSBC), March 24-25, 2009, San
Francisco,
> > CA
> >> -OSBC tackles the biggest issue in open source: Open Sourcing the
> > Enterprise
> >> -Strategies to boost innovation and cut costs with open source
> > participation
> >> -Receive a $600 discount off the registration fee with the source code:
> > SFAD
> >> http://p.sf.net/sfu/XcvMzF8H
> >> _______________________________________________
> >> Geomoose-users mailing list
> >> Geomoose-users at lists.sourceforge.net
> >> https://lists.sourceforge.net/lists/listinfo/geomoose-users
Francisco,
> CA
> Enterprise
> participation
> SFAD
> Open Source Business Conference (OSBC), March 24-25, 2009, San Francisco,
CA
Enterprise
participation
SFAD
CA
Enterprise
participation
SFAD
Name: IE debug.png
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/geomoose-users/attachments/20090225/6adecc0e/IEdebug.png
More information about the Geomoose-users mailing list
