[Geomoose-users] [Geomoose-developers] Highlight results of Search
Nelson Soto NSoto at plotplans.com
Fri Feb 27 09:36:35 EST 2009
Jay,
As Brian mentions, a custom PHP script is the way to go here. I wrote a
custom script that highlighted multiple features based on specific IDs
as an input. The code is not public and I can't really lend much help on
it but what I wanted to do was suggest for you to start by looking at
the buffer selection PHP file.
IIRC, the buffer tool runs a search and then exports the result to a new
shape file which then gets dynamically added to the map for viewing. All
of this is transparent to the user. You can use this process to loops
through the results of your "fuzzy" search and then add each feature to
the shapefile and display it accordingly.
This is all the help I can get you but you should be able to get the
gist of it at this point. Keep at it!
From: Fischer, Brian [mailto:bfischer at houstoneng.com]
Sent: Thursday, February 26, 2009 2:38 PM
To: Jay Kapalczynski; geomoose-users at lists.sourceforge.net;
geomoose-developers at lists.sourceforge.net
Subject: Re: [Geomoose-developers] Highlight results of Search
I've done it for one of my clients, but it was a custom PHP mapscript
service that was written to only work with their data.
So short answer is no, unless you write your own code to do it.
Brian Fischer
Houston Engineering, Inc.
Maple Grove, MN
(763) 493-4522
From: Jay Kapalczynski [mailto:jkapalczynski at ci.maple-grove.mn.us]
Sent: Thursday, February 26, 2009 11:52 AM
To: geomoose-users at lists.sourceforge.net;
Subject: [Geomoose-developers] Highlight results of Search
Wondering if anyone has done this or knows where I might start?
I want to run a search, say on PID (parcel number)...
Ex..1211925260012  but I do a search for 121192526
This returns me about 30 PID address...I would like the results to
highlight or select in the map
Thoughts?
Thanks
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20090227/076066f9/attachment.html
More information about the Geomoose-users mailing list
