[Geomoose-users] where to look for errors - Trouble with URLs
Dan Little danlittle at yahoo.com
Wed Jan 7 19:13:53 EST 2009
Sacha,
There are two different bugs, can you send the Mapbook fragment defining the WMS service? I think it may have a typo that is putting in the extra semi-colon.
The other problem can be fixed in two ways:
1) Set the layer status to "default."  In GM 1.X this is the typical way of defining a layer.
2) Set the "layers" param in the <map> tag...
<map title="Something" ...>
<file>...</file>
<param name="layers" value="mylayername"/>
</map>
----- Original Message ----
> From: Sacha Black <sacha.black at gmail.com>
> To: geomoose-users at lists.sourceforge.net
> Sent: Wednesday, January 7, 2009 6:08:29 PM
> Subject: Re: [Geomoose-users] where to look for errors - Trouble with URLs
> On Mon, Dec 15, 2008 at 5:53 PM, Fischer, Brian
> wrote:
> > Sacha,
> > Your best option will be to use firebug to see what javascript errors it
> > is giving you.  If there are no javascript errors, than you will want to
> > look at the URL that is being generated to call mapserver to make the
> > image.  Those will also show up in firebug under the net tab.  Hope this
> > helps,
> > Brian
> Thanks Brian,
> Firebug is helping me figure things out.
> First I had issues with the symbolset and fonts paths, and once that
> was sorted, I came to 2 errors that I think are being generated by
> GeoMOOSE when it creates the URLs to send to Mapserver. I'm sure I
> probably missed something in setup that is causing the problem.
> If anyone has any idea about either of these problems I would be most
> grateful for the hints...
> sacha
> here is an example of the first error with a regular, local, non-WMS layer:
> http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apps/geomoose/maps_mydemo/./parks/parks_8bit.map&mapext=-834744.6077081193%20655019.564290853%201608541.8577081193%201224697.755709147&mapsize=965%20225&mode=map&layers=&MOOSETIME=1231371797094
> the problem looks like the name of the layer is not being inserted
> after "&layers=" .... knowing where to specify this in my GeoMOOSE
> setup will help alot, as this is happening for all my local layers. If
> it helps, here is the relevant mapfile layer:
> LAYER
>   NAME  State_Park
>   STATUS ON
>   TYPE  POLYGON
>   LABELITEM "Name"
>   DATA "C:/mydata/parks_w_linebreaks.shp"
> CLASS
> NAME 'National, State or Local Park'
>   STYLE
>    COLOR  168 203 150
>   END
>     label
>       type truetype
>       antialias true
>       font tuffy_bold
>       size 7
>       position cc
>       color 35 73 27
>       outlinecolor 255 255 255
>       buffer 5
>       partials false
>       minfeaturesize 100
>       wrap "*"
>       end
> END
> END
> I have a second, different problem with the one WMS layer I am trying
> to use, that is also a result of a badly formed URL, and in this case
> I do not know if the problem is mine or not.
> for the following WMS layer:
> LAYER
>     GROUP "Color Photos 2005"
>     NAME "Ortho2005"
>     TYPE RASTER
>     CONNECTIONTYPE WMS
>     STATUS OFF
>     TRANSPARENCY 65
>     CONNECTION "http://wms.oregonexplorer.info/ImageX/ecw_wms.dll?"
>     PROJECTION
>       "init=epsg:2992"
>     END
>     METADATA
>       "wms_srs"             "EPSG:2992"
>       "WMS_name"        "2005ORTHOIMAGERY.ECW"
>       "wms_server_version"  "1.1.1"
>       "wms_format"          "image/png"
>       "wms_transparent"        "TRUE"
>       "wms_bgcolor"         "0x000000"
>       IMAGEFORMAT "AGGA"
>     END
>     PROJECTION
>       "init=epsg:2992"
>     END
> END
> GeoMOOSE is creating the following URL which is broken because of the
> ";" after the "FORMAT=image/png" :
> http://wms.oregonexplorer.info/ImageX/ecw_wms.dll?LAYERS=2005ORTHOIMAGERY.ECW&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&FORMAT=image/png;SRS=EPSG:2992&BBOX=-834744.6077081193,655019.564290853,1608541.8577081193,1224697.755709147&WIDTH=965&HEIGHT=225&MOOSETIME=1231372918836
> This second error seems like it could be a bug in GeoMOOSE, but I
> don't know enough to know.
> Check out the new SourceForge.net Marketplace.
> It is the best place to buy or sell services for
> just about anything Open Source.
> http://p.sf.net/sfu/Xq1LFB
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
