[Geomoose-users] Legend issue
CoFIS Web coffee at uni-bonn.de
Wed Jul 29 08:09:22 EDT 2009
Dear all,
thanks to suggestion on the mapserver list, I replaced the dashes in my
layer names (in the mapfile & mapbook) with underscores and now the
problem is gone - almost:
I can switch on and off the individual layers and they only appear at
their respective positions in the legend. However, if I switch one of
the layers of may mapfile on (from the legend) I can show the signature
of the other layer in the legend by using the drop-down button without
this particular layer being switched on (screenshot).
Can this be changed somehow? If you need to see my mapfile, I'd be happy
to send it.
Thanks,
Nils
CoFIS Web schrieb:
> Dear Len,
> yes, the layers are in the same mapfile. I tried setting the STATUS to
> ON and OFF at layer level. But still it results in the same issue -
> signatures of both layers appear in the legend.
> Any hints? I'll search the Mapserver mailing list as well.
> Thanks,
> Nils
> Len Kne schrieb:
>> Are both layers in the same mapfile?  If yes, check the layer STATUS
>> in your mapfile.  If STATUS is set to DEFAULT, that layer is included
>> whenever a request for a legend is made.  Try setting STATUS to ON.
>> Len
>> ______________________________
>> Len Kne
>> lenkne at yahoo.com
>> *From:* CoFIS Web <coffee at uni-bonn.de>
>> *To:* GeoMoose Mailing list <geomoose-users at lists.sourceforge.net>
>> *Sent:* Thursday, June 25, 2009 2:48:55 AM
>> *Subject:* [Geomoose-users] Legend issue
>> Dear all,
>> in GM2 I have a mapfile with two layers.
>> When turning the first of these layers on from the legend, the
>> respective signature will appear in the legend at its respective
>> location (as expected) AND the location of the second layer. When
>> turning the second layer on, its signature will appear on its
>> respective location in the legend (as expected) AND be added to the
>> legend signature of the first layer (not wanted).
>> How can I change this? I added two screenshots for clarification.
>> Mapbook snippets are below.
>> Thanks,
>> Nils
>> <map-source name="conservation" type="mapserver" reference="true">
>>   <file>./conservation.map</file>
>>   <layer name="nfpa"/>
>>   <layer name="biores_ecff-yayu01"/>
>> </map-source>
>> <group title="Conservation" expand="false">
>>   <layer title="National Forest Priority Areas"
>> src="conservation/nfpa" legend="true" status="off"/>
>>   <layer title="Yayu Biosphere Reserve (Proposal)"
>> src="conservation/biores_ecff-yayu01" legend="true" status="on"/>
>> </group>
>> -- Center for Development Research
>> Department of Ecology and Resource Management
>> Walter-Flex-Strasse 3
>> 53113 Bonn (Germany)
>> Tel.:  +49 (0) 228 - 73-1793
>> FAX:    +49 (0) 228 - 73-1889
>> E-Mail: coffee at uni-bonn.de <mailto:coffee at uni-bonn.de>
>> Web:    http://www.cofis.info/atlas
>>         http://www.coffee.uni-bonn.de
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/geomoose-users/attachments/20090729/b3c0c204/two-layers.png
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/geomoose-users/attachments/20090729/b3c0c204/one-layer.png
More information about the Geomoose-users mailing list
