[Geomoose-users] Legend issue
Dan Little danlittle at yahoo.com
Wed Jul 29 14:38:06 EDT 2009
I marked this in trac as ticket #4.
----- Original Message ----
> From: CoFIS Web <coffee at uni-bonn.de>
> To: GeoMoose Mailing list <geomoose-users at lists.sourceforge.net>
> Sent: Wednesday, July 29, 2009 7:09:22 AM
> Subject: Re: [Geomoose-users] Legend issue
> Dear all,
> thanks to suggestion on the mapserver list, I replaced the dashes in my layer
> names (in the mapfile & mapbook) with underscores and now the problem is gone -
> almost:
> I can switch on and off the individual layers and they only appear at their
> respective positions in the legend. However, if I switch one of the layers of
> may mapfile on (from the legend) I can show the signature of the other layer in
> the legend by using the drop-down button without this particular layer being
> switched on (screenshot).
> Can this be changed somehow? If you need to see my mapfile, I'd be happy to send
> it.
> Thanks,
> Nils
> CoFIS Web schrieb:
> > Dear Len,
> > yes, the layers are in the same mapfile. I tried setting the STATUS to ON and
> OFF at layer level. But still it results in the same issue - signatures of both
> layers appear in the legend.
> > Any hints? I'll search the Mapserver mailing list as well.
> > Thanks,
> > Nils
> > Len Kne schrieb:
> >> Are both layers in the same mapfile?  If yes, check the layer STATUS in your
> mapfile.  If STATUS is set to DEFAULT, that layer is included whenever a request
> for a legend is made.  Try setting STATUS to ON.
> >> Len
> >>  ______________________________
> >> Len Kne
> >> lenkne at yahoo.com
> >> *From:* CoFIS Web
> >> *To:* GeoMoose Mailing list
> >> *Sent:* Thursday, June 25, 2009 2:48:55 AM
> >> *Subject:* [Geomoose-users] Legend issue
> >> Dear all,
> >> in GM2 I have a mapfile with two layers.
> >> When turning the first of these layers on from the legend, the respective
> signature will appear in the legend at its respective location (as expected) AND
> the location of the second layer. When turning the second layer on, its
> signature will appear on its respective location in the legend (as expected) AND
> be added to the legend signature of the first layer (not wanted).
> >> How can I change this? I added two screenshots for clarification. Mapbook
> snippets are below.
> >> Thanks,
> >> Nils
> >>  ./conservation.map
> legend="true" status="off"/>
> src="conservation/biores_ecff-yayu01" legend="true" status="on"/>
> >> -- Center for Development Research
> >> Department of Ecology and Resource Management
> >> Walter-Flex-Strasse 3
> >> 53113 Bonn (Germany)
> >> Tel.:  +49 (0) 228 - 73-1793
> >> FAX:    +49 (0) 228 - 73-1889
> >> E-Mail: coffee at uni-bonn.de
> >> Web:    http://www.cofis.info/atlas
> >>         http://www.coffee.uni-bonn.de
More information about the Geomoose-users mailing list
