[Geomoose-users] Select Info to a new window - A solution and a tip
Brent Fraser bfraser at geoanalytic.com
Mon Jun 1 12:46:59 EDT 2009
To all,
A solution:
  Following Dan's suggestion I edited the select.php to include:
} elseif($output == 'bare-html') {
	header('Content-type: text/html');
	print "<head>\n";
	print "</head>";
	print "<body>";
	print $template;
	print "</body>";
	print "</html>";
and added display="window" to my "select Feature" service attributes in my application's xml config file:
        <service title="Select Feature" default="true" display="window"
as well as changing the output type:
            <input type="hidden" name="output" value="bare-html"/>
And a tip:
 To get the results sent to the same window on each select operation (instead of separate windows being created each time), I added target="MySelection" to the service attributes:
        <service title="Select Feature" default="true" display="window" target="MySelection"
 The value can be anything, it just needs to be a named target.
Brent Fraser
Brent Fraser wrote:
> I had a look at the HTML generated by the SELECT service (not the IDENTIFY):
> <html xmlns:moose="http://geomoose.org/"><head>
> <moose:mapbook>
> <moose:map title='Highlight' default='true'>
> 	<moose:file>../../TopoCan/select.map</moose:file>	<moose:param name='layers' value='Wells'/>	<moose:param name='qlayer'
> It doesn't render very well when sent to a new window (using the display="window" tag in the Select service.)
> Any thoughts on how to fix this?
> Thanks!
> Brent
> Brent Fraser wrote:
>> Brian,
>>   I just found the display tag while sifting thru ServiceManager.js  It seems to work ok for Identify, but for Select it opens a new window and prints the value of the map tag, e.g:
>> ./select.map
>> strange...
>> Many Thanks!
>> Brent
>> Brian Fischer wrote:
>>> Brent,
>>> This use to work, but haven't tried it in a while.  You could set the display attribute of the service tag to display="window" and it would pop the results up in a new window.  Give that a try.  Here is the documentation we wrote on it:
>>> http://www.geomoose.org/moose/index.php?option=com_content&task=view&id=14&Itemid=29 Look at the display attribute under <service> section.
>>> Also I had Dan write a little custom feature for me to create a link to open the results tab up in a new window so users could print it.  I think he mainly did it with some JavaScript and CSS.  Here is the app that is doing that. http://klamathcounty
>> houstoneng.com/klamathmap/klamathmap.html Select some parcels with the mailing labels tool or Identify tool then click on the "Print Info. Tab" in the menubar.
>>> Hope this helps,
>>> Brian
>>> Brian Fischer, CFM  GIS Project Manager
>>> Houston Engineering, Inc.
>>> Phone: W: 763.493.4522 / M: 763.229.2734
>>> -----Original Message-----
>>> From: Brent Fraser [mailto:bfraser at geoanalytic.com]
>>> Sent: Thursday, May 28, 2009 11:36 AM
>>> To: Dan Little
>>> Cc: GeoMOOSE Users List
>>> Subject: Re: [Geomoose-users] Info from Select to a new window?
>>> Dan,
>>>  I'm using V1.6.1.
>>> It looks like the target of the html/text generated by select.php is set around line 488 in ServiceManager.js (of course I could be totally out-to-lunch as my JavaScript is weak):
>>> 	} else if(returnType.match(/text/i) || contentType.match(/plain/i)){ // Plain Text Return
>>> 		var results = document.getElementById('content_results_form');
>>> 		var text = http.responseText;
>>> 		if(!(text.match(/\<html/))) {
>>> 			text = text.replace(/\n/g,'<br/>\n');
>>> 			text = '<tt>'+text+'</tt>';
>>> 		results.innerHTML = text;
>>> 		EventManager.triggerEvent('changetab',TABS_RESULTS_NAME);
>>> 	} else if(returnType.match(/csv/i) || contentType.match(/csv/i)) { // CSV return type
>>> perhaps if do something like:
>>> 		var win = window.open("", "Results", "width=100, height=100, scrollbars=yes" );
>>> 		var results2 = win.document.body;
>>> 		results2.innerHTML = text;
>>> Any thoughts on that?
>>> Thanks!
>>> Brent
>>> Dan Little wrote:
>>>> 1.6 or 2.0?
>>>> ----- Original Message ----
>>>>> From: Brent Fraser <bfraser at geoanalytic.com>
>>>>> To: GeoMOOSE Users List <geomoose-users at lists.sourceforge.net>
>>>>> Sent: Wednesday, May 27, 2009 11:35:08 AM
>>>>> Subject: [Geomoose-users] Info from Select to a new window?
>>>>> I'd like to send the attribute information of my selected features to a new
>>>>> browser window instead of the Information tab.  What's a good way to do this?
>>>>> Thanks!
>>>>> Brent Fraser
>>>>> Register Now for Creativity and Technology (CaT), June 3rd, NYC. CaT
>>>>> is a gathering of tech-side developers & brand creativity professionals. Meet
>>>>> the minds behind Google Creative Lab, Visual Complexity, Processing, &
>>>>> iPhoneDevCamp as they present alongside digital heavyweights like Barbarian
>>>>> Group, R/GA, & Big Spaceship. http://p.sf.net/sfu/creativitycat-com
>>>>> _______________________________________________
>>>>> Geomoose-users mailing list
>>>>> Geomoose-users at lists.sourceforge.net
>>>>> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
