[Geomoose-users] GM 2.0- tiling performance in county projections / is it possible to add a custom coordinate to the status bar while using UTM?
Brent Fraser bfraser at geoanalytic.com
Fri Jun 12 10:30:29 EDT 2009
Dan,
  So is OpenLayers doing the re-projection of the WMS image on the client?  Wow!
Brent
Dan Little wrote:
> http://www.geomoose.org/geomoose2/docs/howto/wms_project.html
> This allows a service to be in a different projection than the Main map with no mapserver reprojection.  However, it is currently broken with tiles.  It's something I have to fix.  Maybe tonight, maybe this weekend, maybe early next week.  I'm really ho
> ping to round out the GM2.0 documentation and make an official release.
> -Duck
> ----- Original Message ----
>> From: Mark Volz <MarkVolz at co.lyon.mn.us>
>> To: Dan Little <danlittle at yahoo.com>
>> Sent: Thursday, June 11, 2009 3:10:22 PM
>> Subject: RE: [Geomoose-users] GM 2.0- tiling performance in county projections / is it possible to add a custom coordinate to the status bar while using UTM?
>> Dan,
>> I noticed your reply.  I was able to get the map projection and display
>> coordinates in Lyon County format.  However when I did so what happened was
>> that the performance of GM slowed way down when I was using tiles in county
>> coordinates.  I do realize that I can turn tiles off, However what I would
>> really like to do is have the best of both worlds:  keep the actual map in
>> UTM-15 which allows me to use tiling without reprojecting (ie fast) while
>> having the status bar display XY in county coordinates so that county
>> coordinate users stay happy.
>> Mark Volz
>> GIS Specialist
>> Lyon County, MN
>> (507) 532-8218
>> -----Original Message-----
>> From: Dan Little [mailto:danlittle at yahoo.com]
>> Sent: Thursday, June 11, 2009 2:47 PM
>> To: Brent Fraser; Mark Volz
>> Cc: geomoose-users at lists.sourceforge.net
>> Subject: Re: [Geomoose-users] GM 2.0- tiling performance in county
>> while using UTM?
>> HTH,
>> http://www.geomoose.org/geomoose2/docs/docs/projections.html
>>> From: Brent Fraser
>>> To: Mark Volz
>>> Sent: Thursday, June 11, 2009 2:44:15 PM
>> while using UTM?
>>> Mark,
>>>   I think you're on the right track.  I see that the std GeoMoose.html does
>>> at line 52.  Perhaps the CountyProjection = new
>>> OpenLayers.Projection('EPSG127083'); does a look-up ?
>>> Maybe you need to make a proj4js/lib/defs/EPSG127083.js?
>>> Brent
>>> Mark Volz wrote:
>>>> Brent,
>>>> I took a look at trying to get custom coordinates to display on a UTM
>>>> map by modifying the compiled.js file.  It appears that openlayers
>>>> handles work for converting the coordinates.  I do not know how
>>>> difficult it would be to add the township and range to the status bar.
>>>> Attached below are the lines that I modified to try to get our
>>>> coordinates to dsiplay.  The code returns an error at line 1600 stating:
>>>> CountyProjection is not defined.  I am defining the CountyProjection on
>>>> line 1551 however I wonder if OpenLayers is unable to find my custom
>>>> projection.  Any thoughts would be helpful.
>>>> Line 43
>>>> 'coordinate_display' : {
>>>>             xy: true,   /* Ground Units */
>>>>             latlon: true,     /* Longitude and Latitude */
>>>>             usng: true, /* U.S. National Grid */
>>>>             *county: true      /* County Projection */*
>>>> Line 738
>>>>             *county: true      /* County Projection test*/*
>>>> Line 1550
>>>>       LatLongProjection = new OpenLayers.Projection('WGS84');
>>>>       *CountyProjection = new OpenLayers.Projection('EPSG127083');*
>>>> Line 1580
>>>>       OpenLayers.Projection.transform(degrees,
>>>>             Map.getProjectionObject(),
>>>>             LatLongProjection);
>>>>       if(CONFIGURATION.coordinate_display.latlon) {
>>>>             html += 'Lat, Lon: ';
>>>>             html += degrees.x.toFixed(3) + ', ' + degrees.y.toFixed(3);
>>>> *      OpenLayers.Projection.transform(degrees, *
>>>> *            Map.getProjectionObject(),*
>>>> *            CountyProjection);*
>>>> *      if(CONFIGURATION.coordinate_display.county) {*
>>>> *            html += 'X, Y: ';*
>>>> *            html += degrees.x.toFixed(3) + ', ' + degrees.y.toFixed(3);*
>>>> Line 3560
>>>>             if(this.xml.getAttribute('reproject')) {
>>>>                   var new_proj = this.xml.getAttribute('reproject');
>>>>                   if(new_proj == 'EPSG:4326' || new_proj == 'WGS84') {
>>>>                         dest_proj = LatLongProjection;
>>>>                   } *else if(new_proj == 'EPSG127083') {*
>>>> *                        dest_proj = CountyProjection;  *
>>>>                   *}*  else {
>>>>                         dest_proj = OpenLayers.Projection(new_proj);
>>>>                   OpenLayers.Projection.transform(f.geometry,
>>>>                         dest_proj);
>>>>             var input = Catalog.createElement('input');
>>>>             input.setAttribute('name', stepName);
>> input.appendChild(Catalog.createCDATASection(output.write(f)));
>>>>             this.xml.appendChild(input);
>>>> Mark Volz
>>>> GIS Specialist
>>>> Lyon County, MN
>>>> (507) 532-8218
>>>> From: Brent Fraser [mailto:bfraser at geoanalytic.com]
>>>> Sent: Thursday, June 11, 2009 1:19 PM
>>>> To: Mark Volz
>>>> Mark,
>>>>   I haven't looked at the tiling so I can't comment on the performance
>>>> issue.
>>>>   As for the coordinate display, I see that stock GeoMoose v2.0 now
>>>> allows for three simultaneous coordinate displays:
>>>>       - projected X/Y
>>>>       - geographic Lat/Lon
>>>>       - USNG
>>>>   It would be nice if it was instead a flexible list of any number of
>>>> reference systems that took lat/lon as input and returned a string to be
>>>> displayed.
>>>>   I'm interested in displaying Township/Range values for example, so I'd
>>>> have to write the JavaScript to do the conversion, but it would be nice
>>>> to be able to easily plug it in stock GeoMoose somewhere, similar to the
>>>> way custom projections work in v1.6.1.
>>>> Brent Fraser
>>>> Mark Volz wrote:
>>>>>  Hello,
>>>>>  Our users want to use county projections within our mapping
>>>>>  application.  In GM 1.6.1 We decided that there was only a minimal
>>>>>  performance hit for the LMIC WMS service(s) to reproject on the fly.
>>>>>  This is not true in GM 2.0.  GM 2.0 allows users the option of using a
>>>>>  tile scheme on the WMS layers.  I was impressed with the speed of the
>>>>>  WMS services on the demo.  Recently I ported the GM 2.0 demo over into
>>>>>  county projections.  I noticed there is a *huge *performance hit if
>>>>>  tiling is turned on.
>>>>>  This left me with a couple options:  1)  I can leave the tiling system
>>>>>  off, and the WMS performance would be similar to that of a 1.6 app.  2)
>>>>>  I can abandon the county projection in favor of utm so that I can use
>>>>>  tile cache and hope that no one complains too much that the map is no
>>>>>  longer in county coordinates.
>>>>>  Another thought I had is if I decided to use UTM (to take advantage of
>>>>>  tiling) would it be possible for me to display the XY location in
>> county
>>>>>  coordinates?  If so, does anyone know what file(s) would need to be
>>>>>  modified so that I can display county coordinates in the status bar?
>>>>>  Thanks
>>>>>  Mark Volz
>>>>>  GIS Specialist
>>>>>  Lyon County, MN
>>>>>  Crystal Reports - New Free Runtime and 30 Day Trial
>>>>>  Check out the new simplified licensing option that enables unlimited
>>>>>  royalty-free distribution of the report engine for externally facing
>>>>>  server and web deployment.
>>>>>  http://p.sf.net/sfu/businessobjects
>>>>>  _______________________________________________
>>>>>  Geomoose-users mailing list
>>>>>  Geomoose-users at lists.sourceforge.net
>>>>>  https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
