[Geomoose-users] Identifying layers problem
Dan Little danlittle at yahoo.com
Sun Jun 28 13:34:20 EDT 2009
The problem is with the name in the layer in the identify.map file.
If the name is "Fire stations 2" in your mapbook in the identify.map the name of the layer must be "Firestations2"
----- Original Message ----
> From: "awhitley at charter.net" <awhitley at charter.net>
> To: geomoose-users: lists.sourceforge.net <geomoose-users at lists.sourceforge.net>
> Sent: Sunday, June 28, 2009 12:20:42 PM
> Subject: [Geomoose-users] Identifying layers problem
> Hi all,
> Another beginner's question; this one regarding identifying layers on the map.
> Per the How-to at GeoMoose site.
> Layer to identify Firestations
> 1. Created my map file
>    Although I am confused by this insert:
>    WEB
>     INCLUDE "/ms4w/apps/GeoMOOSE/maps_statedemo/web_config.map"
>   END
> I dont see this config.map in statedemo folder
> 2. Added layer to config.xml ( i disregarded the metadata info for now)
> tip="Clearinghouse data">
>           ./countydata/ga_firestations2.map
> 3. Support Identify
> Header and footer and
> identify_fire.ht
> Fire Stations Layer
> Name:
> [NAME]
ml
> 4. Modify identify.map
> LAYER
>             NAME 'ga_firestations2'
>             DATA 'countydata/ga_firestations2.shp'
>             STATUS ON
>             TYPE POINT
>             TOLERANCE 0
>             TEMPLATE 'countydata/identify_fire.html'
>       END
> My reoccuring error when clicking firestation to identify:
> msQueryByPoint(): Search returned no results. No matching record(s) found.
> shp2img = valid map file
> Sorry for long post.
> Tfaustino
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
