[Geomoose-users] Why won't this label layer output any labels
Edward E. Boesenberg, III eboesenberg at niraengineers.com
Tue Mar 10 10:34:40 EDT 2009
I figured out why my label layer wasn’t working, I had to add a STYLE section to the CLASS section in the map file.  I don’t know why it needed a style section but it works.  I didn’t need a style section because I didn’t want the points to plot they are on another layer.
From: Edward E. Boesenberg, III [mailto:eboesenberg at niraengineers.com]
Sent: Monday, March 09, 2009 1:36 PM
To: 'Dan Little'; geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] Why won't this label layer output any labels
Dan,
Mindistance is uncommented but when I comment that line, nothing happens.
Sent: Monday, March 09, 2009 1:31 PM
To: Edward E. Boesenberg, III; geomoose-users at lists.sourceforge.net
What happens when you uncomment the mindistance?
  _____
From: "Edward E. Boesenberg, III" <eboesenberg at niraengineers.com>
To: geomoose-users at lists.sourceforge.net
Sent: Monday, March 9, 2009 12:18:02 PM
Subject: [Geomoose-users] Why won't this label layer output any labels
Can anybody see why this map layer won’t output any labels, when it’s turned on?
Here is the code from my XML file:
<map title="mhol_label" default="false">
<file>./mhol_label/mhol_label.map</file>
</map>
I have other labels in my map the work but for some reason I can’t get this one to work?  I attached the shapefile to see if someone else could get this to work.
Thanks,
Ed
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20090310/0c958708/attachment.html
More information about the Geomoose-users mailing list
