[Geomoose-users] select tool using mapserver
Brent Lund (ADM) Brent.Lund at state.mn.us
Thu Mar 19 09:04:35 EDT 2009
Mmm, ok.   I had the mapserver query set up with another app and thought I could just drop it into geomoose.   I see you are passing multipoint to select.php.  To define the mapext (for mapserver) I would need multipoint[0] and multipoint[2].
>> Mapserver will also not necessarily return the correct information to GeoMOOSE to behave properly.
?  isn't the information returned defined in the map file and associated html template?
Sent: Wednesday, March 18, 2009 3:42 PM
To: Brent Lund (ADM); geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] select tool using mapserver
Hey Brent,
I'm a little curious as to your motivation, what's select.php doing/not-doing that makes you want to use mapserver? Mapserver will also not necessarily return the correct information to GeoMOOSE to behave properly.
-Duck
To: "geomoose-users at lists.sourceforge.net" <geomoose-users at lists.sourceforge.net>
Sent: Wednesday, March 18, 2009 3:04:54 PM
Subject: [Geomoose-users] select tool using mapserver
Greetings,
I would like to use select tool with /cgi-bin/mapserv (instead of php/select.php).
Using the state demo as a starting point, I figured I could take the identify tool and
1)     switch shape="point" to shape="box"
2)      replace <input type="point" name="mapxy" delim=" "/> with <input type="box" name="mapext" delim=" "/>
but generates the following mapserver error:
"loadForm(): Web application error. Not enough arguments for mapext."
Thanks,
Brent
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20090319/f5a873a6/attachment.html
More information about the Geomoose-users mailing list
