[Geomoose-users] Identify - where to look for error spec
Dan Little danlittle at yahoo.com
Tue Mar 24 10:34:47 EDT 2009
Try changing your TOLERANCE and TOLERANCEUNITS pixels are notorious bad and usually not calculated correctly.
MfG,
-Duck
----- Original Message ----
> From: CoFIS Web <coffee at uni-bonn.de>
> To: GeoMoose Mailing list <geomoose-users at lists.sourceforge.net>
> Sent: Tuesday, March 24, 2009 5:35:02 AM
> Subject: [Geomoose-users] Identify - where to look for error spec
> Dear list,
> I try to adapt the identify tool from the demos to my own app.
> Unfortunately, I get the "No information found in the area you clicked,
> please try again." error from query_miss.html.
> I have used the identify.map, header and footer as well as template.html
> files - Did I miss one?
> I have set a log file to find out whats going wrong, but this only tells me:
> Tue Mar 24 11:29:47 2009,21609,131.220.109.14,Identify tool - for all
> layers,10,-165000.000000 350000.000000 1500000.000000
> 1700000.000000,404216.867470 1327710.843373,ScaleBar Highlight
> Administrativeboundaries Weredatest Townsandvillages RoadsandRailway
> CoCEFieldresearch Forestcover2005 ,msQueryByPoint(): Search returned no
> results. No matching record(s) found.
> From the layers mentioned, I have set up identify for the Weredatest
> layer and double checked that the items I query in the identify.html do
> match the field names in my shape file.
> My identify.map looks like this:
> MAP
>   NAME 'Identify tool - for all layers'
>   SIZE 750 750
>   EXTENT    -165000    350000    1500000    1700000
>   STATUS        on
>   UNITS        meters
>   TRANSPARENT    true
>   IMAGETYPE    png
>   QUERYMAP
>    STATUS    on
>    STYLE    selected
>   END # QUERYMAP
>   WEB
>    LOG    '../../log/geomoose/identify.map'
>    INCLUDE '../defaults/map_temp-path.map'
>    HEADER  './identify_header.html'
>    FOOTER  './identify_footer.html'
>    EMPTY   '/atlas/query_miss.html'
>   END # WEB
>   LAYER
>    NAME 'Wereda'
>    DATA '../../vector/base-data/admin_04_wereda'
>    STATUS on
>    TYPE polygon
>    TOLERANCE 7
>    TEMPLATE './identify_boundary-all.html'
>    METADATA
>     qstring_validation_pattern '.'
>    END
>   END # Layer
> END #Map
> Does that look alright? Where else could I check for more meaningful errors?
> Thanks in advance,
> Nils
> Center for Development Research
> Department of Ecology and Resource Management
> Walter-Flex-Strasse 3
> 53113 Bonn (Germany)
> Tel.:   +49 (0) 228 - 73-1793
> FAX:    +49 (0) 228 - 73-1889
> E-Mail: coffee at uni-bonn.de
> Web:    http://www.cofis.info/atlas
>          http://www.coffee.uni-bonn.de
> Apps built with the Adobe(R) Flex(R) framework and Flex Builder(TM) are
> powering Web 2.0 with engaging, cross-platform capabilities. Quickly and
> easily build your RIAs with Flex Builder, the Eclipse(TM)based development
> software that enables intelligent coding and step-through debugging.
> Download the free 60 day trial. http://p.sf.net/sfu/www-adobe-com
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
