[Geomoose-users] upgrading to 5.2.2 (success and how to)
Mark Volz MarkVolz at co.lyon.mn.us
Mon Mar 30 15:41:51 EDT 2009
Hello,
With the help of Bob Basques, and Steve Lime I was able to get GM upgraded to
5.2.2
I attached the instructions on how I got it up and running.
Updating Mapserver to 5.2.2
Mark Volz
There are new security features within Mapserver 5.2.2.  As a result items in
Geomoose must be changed to enable certain functions to work properly.  These
changes include but are not limited to:
*	Adding a "magic string" to all of the html templates
*	Modifying the symbol set(s)
*	Modifying the .Map files
*	Changing the id for the search boxes
Adding a magic string to html templates:
For each html template you will need to add <!-- MapServer Template --> to
the top of each page.  Templates include files such as identify.html,
itemquery.html, select.html, and the header and footer pages.
Example:
<tr>
<td><b>PID:</b></td>
<td>[PARCEL_ID]
Modifying the Symbol Sets
The basics.sym, and points.sym files in <yourmaps>\symbols needs to include
"SYMBOLSET" as the first line.  Also if you add "SYMBOLSET" make sure you
include an additional "END" at the end of the file.
Example:
SYMBOLSET
  SYMBOL
    NAME 'circle'
    TYPE ELLIPSE
    FILLED TRUE
    POINTS 1 1 END
  END
END #Symbolset
You may need to modify each .map file.  They must have MAP as the first item
then SYMBOLSET as the second item.
Example:
MAP
            SYMBOLSET 'symbols/symbol.sym'
            NAME 'all layers'
Modifying the id of the queries
For each of your searches you may need to make sure that you are not using
"id" as your search string.  The variable "id" is reserved by Mapserver and
therefore is subject to new limitations.  One of those is that any searches
that include a dash in them ("-") will fail.
You will need to rename the variable in 3 files:
In this case I modified the name of the search id from id to SearchID
Map.xml
Update the user input type
<service title="Search for Parcels by Owner Name" selectable="false"
default="false"...
<url>/cgi-bin/mapserv.exe</url>
            <input type="hidden" name="map" value="..."/>
            <input type="hidden" name="mode" value="nquery"/>
            <input type="hidden" name="layer" value="ParcelsOwnerSearch"/>
            <input type="user" name="SearchID" title="Zoom to Parcel#:"/>
</service>
Map.html
Update the input name
<div id="ownersearch">
                        <font color="black"><b>Search for Parcels by Owner ..
                        <input name="SearchID"/><input type="submit"
value="Search"/>
                        <input type="hidden" name="map"...
</div>
All of the itemquery_geographyfile.map files
Update the filter name
                        FILTERITEM 'PARCEL_ID'
                        FILTER /%SearchID%/
Mark Volz
GIS Specialist
Lyon County, MN
(507) 532-8218
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20090330/e16e864d/attachment.html
More information about the Geomoose-users mailing list
