[Geomoose-users] Feature requests and a Tip
Fischer, Brian bfischer at houstoneng.com
Tue May 5 16:49:54 EDT 2009
Brent,
If you know how to get into the SVN you might want to download that version as Dan has added some nice enhancements to the print service and fixed a few bugs.  He also did a great job on updating and creating more documentation.
SVN: http://www.geomoose.org/moose/index.php?option=com_content&task=view&id=29&Itemid=34
GM 2 docs: http://www.geomoose.org/geomoose2/docs/
I'm guessing we'll release a beta 2 in a couple of weeks.
Brian Fischer
Houston Engineering, Inc.
Phone: W: 763.493.4522 / M: 763.229.2734
-----Original Message-----
From: Brent Fraser [mailto:bfraser at geoanalytic.com]
Sent: Tuesday, May 05, 2009 3:24 PM
To: Dan Little
Cc: GeoMOOSE Users List
Subject: Re: [Geomoose-users] Feature requests and a Tip
Darn!  Now I've HAVE to download the Beta and give it a go...
Many Thanks,
Brent
Dan Little wrote:
> Hey Brent thank you for the feature requests and the tip...
> Here's something you might want to look into for 4/5...
> You can actually do "dependent" layers in side of GM2 right now AND use mapserver "layer" levels ... for example...
> <map-source name="labels">
> <file>all/labels.map</file>
> <layer name="county"/>
> <layer name="city"/>
> <layer name="street"/>
> </map-source>
> <map-source name="shapes">
> <file>all/shapes.map</file>
> </map-source>
> Then in the <catalog>, to implement "requires..."
> <layer title="Cities" src="labels/city:shapes/city" status="on"/>
> <layer title="County" src="labels/county:shapes/county" status="on"/>
> Or to implement mapfile level layering...
> <group title="Labels">
> <layer title="City" src="labels/city"/>
> <layer title="County" src="labels/county"/>
> </group>
> <group title="Streets">
> <layer title="Labels" src="labels/street"/>
> <layer title="Lines" src="shapes/street"/>
> </group>
> ----- Original Message ----
>> From: Brent Fraser <bfraser at geoanalytic.com>
>> To: GeoMOOSE Users List <geomoose-users at lists.sourceforge.net>
>> Sent: Tuesday, May 5, 2009 2:35:07 PM
>> Subject: [Geomoose-users] Feature requests and a Tip
>> A few feature requests for Geomoose 2:
>> 1. Make the side panel collapsible like v1.6.1
>> 2. On clicking the Search button, set the keyboard focus to the text box.
>> 3. Have check box at the Group level to turn off/on entire sets of layers.
>> 4. Have dependent layers (like Mapserver's LAYER -> REQUIRES) so if I turn a
>> layer off, it's labels (rendered in a separate map file so they are always on
>> top of everything else) will turn off too.
>> 5. Have check boxes for the Mapserver LAYER level too.
>> And here's a tip for those who like to maximize their mapping:
>>     When using the browser (Firefox, IE, etc) on a GeoMoose site, press F11 to
>> switch to Full-screen mode while in the browser.  This will get rid of all those
>> pesky browser title, status, tool, and menu bars.  Press F11 again to return to
>> standard windowed browsing.  But don't try this with dual (or more!) display
>> setups; Mapserver is set by default to render a maximum of 2048 and the layers
>> will fail to render (for those building GeoMoose sites, set the MAP's MAXSIZE to
>> 4096 or larger to handle dual displays).
>> Best Regards,
>> Brent Fraser
>> GeoAnalytic Inc.
>> The NEW KODAK i700 Series Scanners deliver under ANY circumstances! Your
>> production scanning environment may not be a perfect world - but thanks to
>> Kodak, there's a perfect scanner to get the job done! With the NEW KODAK i700
>> Series Scanner you'll get full speed at 300 dpi even with all image
>> processing features enabled. http://p.sf.net/sfu/kodak-com
>> Geomoose-users mailing list
>> Geomoose-users at lists.sourceforge.net
>> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
