[Geomoose-users] getmapbook.php and Avoiding PHP
Brent Fraser bfraser at geoanalytic.com
Fri May 8 12:24:51 EDT 2009
Dan,
  Many thanks for the over-ride and the doc.  And since I'm the Devil's advocate in this case, here's a proposed edit for the doc:
Why It's Okay
 Here are a couple of reasons to override the mapbook setting:
 o  If you are having difficulty getting PHP working on your server and want to experiment with GeoMoose
 o  You want to use a different server-side scripting language (such as Python or ASP) and are not interested in using the other GeoMoose PHP services.
Thanks again!
Brent
Dan Little wrote:
> I've added some code to SVN this morning that addresses the concerns about getmapbook.php.
> Also, the latest SVN features the latest red-lining tools... they're slick as banana peels.
> Please read the docs on the implementation of this over-ride and let me know if it makes sense:
> http://www.geomoose.org/geomoose2/docs/howto/getmapbook.html
> -Duck
> The NEW KODAK i700 Series Scanners deliver under ANY circumstances! Your
> production scanning environment may not be a perfect world - but thanks to
> Kodak, there's a perfect scanner to get the job done! With the NEW KODAK i700
> Series Scanner you'll get full speed at 300 dpi even with all image
> processing features enabled. http://p.sf.net/sfu/kodak-com
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
