[Geomoose-users] Laserfiche and GeoMoose
Dan Little danlittle at yahoo.com
Mon May 11 17:17:45 EDT 2009
Yep.  There are a number of ways to do that... my instinct would be to do one of the following:
1) Do an external link via the identify templates to the LaserFiche search.  something like...
View'>http://my.server.mn.us/laserfische/search.cgi?id=[PIN]">View related documents
2) Setup a PHP script that can parse the results and then directly link to the documents.  This is pretty detail oriented and I'm sorta lazy but the code would follow this type of path:
a) Download the results of a search from the system into memory.
b) Parse that using a custom parser, or if available get the results in XML or JSON so they can be parsed with a native parser.
c) Process those results into HTML links for the user.
d) Return the HTML to the results tab.
(/end 50 cents)
To: Bob Basques <Bob.Basques at ci.stpaul.mn.us>; geomoose-developers at lists.sourceforge.net; geomoose-users at lists.sourceforge.net
Sent: Monday, May 11, 2009 4:10:45 PM
Subject: Re: [Geomoose-users] Laserfiche and GeoMoose
I guess I would actually like to send a
query to LaserFiche and have that software bring back all the documents
associated with that query.  So for example, you click on a parcel and it
sends the PIN to LaserFiche which brings up all data associated with that
PIN.  Does that make sense?
Blaine
[mailto:Bob.Basques at ci.stpaul.mn.us]
Sent: Monday, May 11, 2009 3:57 PM
To: Blaine Hackett;
Blaine,
When you say link to LaserFiche, are you talking about linking
to a scan of the Lasertfiche, or to something else?  Document linking is
indeed possible to link into GeoMoose, either via the identify button or via
the popup mechanism
bobb
>>> "Blaine Hackett" <blaine at gisrangers.com> wrote:
Good Afternoon!
I have several clients who want to link GeoMoose to
LaserFiche.  Have any of you done that and if so, what is the
difficulty factor?
Thanks
Blaine
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20090511/e7a7a87e/attachment.html
More information about the Geomoose-users mailing list
