[Geomoose-users] GM2 - direct call to WMS without mapfile
CoFIS Web coffee at uni-bonn.de
Tue May 12 08:09:28 EDT 2009
Hi Dan,
my output projection for GM is EPSG:32637 as defined in the mapbook
defaults.
Nils
Dan Little schrieb:
> Hi Nils,
> What is your map projection?
> ----- Original Message ----
>> From: CoFIS Web <coffee at uni-bonn.de>
>> To: GeoMoose Mailing list <geomoose-users at lists.sourceforge.net>
>> Sent: Tuesday, May 12, 2009 6:38:29 AM
>> Subject: [Geomoose-users] GM2 - direct call to WMS without mapfile
>> Dear all,
>> do I understand correctly, that in GM2 I can include WMS into my
>> application without having to us a local mapfile?
>> I try to include the Blue Marble Global Mosaic tiled WMS
>> (http://onearth.jpl.nasa.gov/wms.cgi?request=GetTileService) using the
>> following lines in my mapbook:
>>     src="background-wms/global_mosaic"/>
>> When loading the layer, GM (according to the status bar in Firefox)
>> loads data. However, the only thing displayed are red tiles - no
>> satellite images.
>> Could someone please point me in the right direction what to change?
>> Thanks,
>> Nils
>> Center for Development Research
>> Department of Ecology and Resource Management
>> Walter-Flex-Strasse 3
>> 53113 Bonn (Germany)
>> Tel.:   +49 (0) 228 - 73-1793
>> FAX:    +49 (0) 228 - 73-1889
>> E-Mail: coffee at uni-bonn.de
>> Web:    http://www.cofis.info/atlas
>>          http://www.coffee.uni-bonn.de
>> The NEW KODAK i700 Series Scanners deliver under ANY circumstances! Your
>> production scanning environment may not be a perfect world - but thanks to
>> Kodak, there's a perfect scanner to get the job done! With the NEW KODAK i700
>> Series Scanner you'll get full speed at 300 dpi even with all image
>> processing features enabled. http://p.sf.net/sfu/kodak-com
>> Geomoose-users mailing list
>> Geomoose-users at lists.sourceforge.net
>> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
