[Geomoose-users] search issue with IIS internal users - Geomoose 1.6.1
Brent Fraser bfraser at geoanalytic.com
Wed May 13 10:28:02 EDT 2009
Mark,
 That's strange.  If it were the other way around I'd say look check the content of the <url> tag in the service's definition and ensure URL was fully qualified (http://www.myserver.com/cgi-bin/mapserv.exe instead of just http://myserver/..).  Or just use a relative URL as in the State/county demos: /cgi-bin/mapserv.exe
  Can you get a more specific error?  Is does the search generate an error or just not find any results (when it should).
  I had a problem with searching not finding results until I realized the EXTENT value in the map file DID have a purpose: it limits the search extents!  I had just left in some old values (from a totally different coordinate system) and had relied on the values in the config .js file to set the intial viewing extents.  That worked OK for viewing the map, but prevented any search results from being found.
  When all else fails, use FileMon (http://technet.microsoft.com/en-us/sysinternals/bb896642.aspx) on the server and a HTTP sniffer (such as http://www.ieinspector.com/httpanalyzer/index.html) on the client and step through the search.
Best Regards,
Brent Fraser
Mark Volz wrote:
> Hello,
> I have geomoose installed on an IIS server.  I was informed that
> internal users are unable to perform searches.  The site does work fine
> for external users.  All other functions seem to be working fine e.g.
> printing, id etc.  I am assuming that this might be a permission issue.
> Does anyone have any ideas on what I should look for to fix this?
> Mark Volz
> GIS Specialist
> Lyon County, MN
> (507) 532-8218
> The NEW KODAK i700 Series Scanners deliver under ANY circumstances! Your
> production scanning environment may not be a perfect world - but thanks to
> Kodak, there's a perfect scanner to get the job done! With the NEW KODAK i700
> Series Scanner you'll get full speed at 300 dpi even with all image
> processing features enabled. http://p.sf.net/sfu/kodak-com
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
