[Geomoose-users] GM2 - direct call to WMS without mapfile
CoFIS Web coffee at uni-bonn.de
Tue May 19 11:28:51 EDT 2009
ups, one step back.
Yes it does work, but not if I request the tiled service by setting
<map-source ... tiled="true">.
Nils
CoFIS Web schrieb:
> Great, it works.
> Nils
> Dan Little schrieb:
>> I have the WMS layer reprojection working in SVN.
>> And I even wrote some documentation...
>> http://www.geomoose.org/geomoose2/docs/howto/wms_project.html
>> I've tested going from UTM-15 to EPSG:4326 (using the nasa world mosaic you posted earlier).
>> ----- Original Message ----
>>> From: Dan Little <danlittle at yahoo.com>
>>> To: coffee at uni-bonn.de
>>> Cc: GeoMoose Mailing list <geomoose-users at lists.sourceforge.net>
>>> Sent: Tuesday, May 12, 2009 7:12:39 AM
>>> Subject: Re: [Geomoose-users] GM2 - direct call to WMS without mapfile
>>> The error is with the reprojection. I will research what it will take to get
>>> this to work today and see if I can get a solution.
>>>> From: CoFIS Web
>>>> To: Dan Little
>>>> Sent: Tuesday, May 12, 2009 7:09:28 AM
>>>> Hi Dan,
>>>> my output projection for GM is EPSG:32637 as defined in the mapbook defaults.
>>>> Nils
>>>> Dan Little schrieb:
>>>>> Hi Nils,
>>>>> What is your map projection?
>>>>>> From: CoFIS Web
>>>>>> To: GeoMoose Mailing list
>>>>>> Sent: Tuesday, May 12, 2009 6:38:29 AM
>>>>>> Subject: [Geomoose-users] GM2 - direct call to WMS without mapfile
>>>>>> Dear all,
>>>>>> do I understand correctly, that in GM2 I can include WMS into my
>>> application
>>>> without having to us a local mapfile?
>>>>>> I try to include the Blue Marble Global Mosaic tiled WMS
>>>> (http://onearth.jpl.nasa.gov/wms.cgi?request=GetTileService) using the
>>> following
>>>> lines in my mapbook:
>>>>>>         src="background-wms/global_mosaic"/>
>>>>>> When loading the layer, GM (according to the status bar in Firefox) loads
>>>> data. However, the only thing displayed are red tiles - no satellite images.
>>>>>> Could someone please point me in the right direction what to change?
>>>>>> Thanks,
>>>>>> Nils
>>>>>> -- Center for Development Research
>>>>>> Department of Ecology and Resource Management
>>>>>> Walter-Flex-Strasse 3
>>>>>> 53113 Bonn (Germany)
>>>>>> Tel.:   +49 (0) 228 - 73-1793
>>>>>> FAX:    +49 (0) 228 - 73-1889
>>>>>> E-Mail: coffee at uni-bonn.de
>>>>>> Web:    http://www.cofis.info/atlas
>>>>>>          http://www.coffee.uni-bonn.de
>>>>>> The NEW KODAK i700 Series Scanners deliver under ANY circumstances! Your
>>>>>> production scanning environment may not be a perfect world - but thanks to
>>>>>> Kodak, there's a perfect scanner to get the job done! With the NEW KODAK
>>> i700
>>>>>> Series Scanner you'll get full speed at 300 dpi even with all image
>>>> processing features enabled. http://p.sf.net/sfu/kodak-com
>>>>>> _______________________________________________
>>>>>> Geomoose-users mailing list
>>>>>> Geomoose-users at lists.sourceforge.net
>>>>>> https://lists.sourceforge.net/lists/listinfo/geomoose-users
>>> i700
>>> processing
>>> Kodak, there's a perfect scanner to get the job done! With the NEW KODAK i700
More information about the Geomoose-users mailing list
