[Geomoose-users] [Geomoose-developers] Buffer Problems
Nelson Soto NSoto at plotplans.com
Fri May 22 10:15:04 EDT 2009
There are intermittent issues with GM 1.6 is you are using that. I don't
know if they would be related to this, but I'd highly recommend porting
your work to GM 2 and give that a shot.
From: Jay Kapalczynski [mailto:jkapalczynski at ci.maple-grove.mn.us]
Sent: Friday, May 22, 2009 10:10 AM
To: geomoose-users at lists.sourceforge.net;
geomoose-developers at lists.sourceforge.net
Subject: [Geomoose-developers] Buffer Problems
I have had this app running for some time now.  I haven't touched
anything in a few months.
I went back in and tried to do a buffer by line and am getting
errors...I tried this on the other select buttons and the same error.
Nothing changed in my:
*         Maple Grove_demo.xml
*         Select.map
*         Buffer_select.map
Why all of a sudden does the query not find the parcels?
Any thoughts?
FIREFOX:
<br />
<b>Warning</b>:  [MapServer Error]: msQueryByShape(): No matching
record(s) found.
 in <b>C:\ms4w\apps\GeoMOOSE\htdocs\php\buffer_select.php</b> on line
<b>139</b><br />
<html><head><title>Mailing Label Service
Error</title></head><body><h3>Service Message</h3><b style='color
:red'>Query Failed to return any results!</b></body></html>
LINE 139:
# Perform the Query.
$queryResultCheck = $queryMap->queryByShape($shape);
if($queryResultCheck == MS_FAILURE) {                            # If
the query fails, error out.
                # Check to see if the Map has any pointers to an empty
file
                $empty = $queryMap->web->empty;
                # If it's set then show that HTML instead. :D
                if(isset($empty) and $empty != '') {
                                readfile($empty);
                                exit(0);
                } else {
                                appError('Query Failed to return any
results!');
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20090522/2eeaa1fc/attachment.html
More information about the Geomoose-users mailing list
