[Geomoose-users] [Geomoose-developers] Buffer Problems
    Jay Kapalczynski
    jkapalczynski at ci.maple-grove.mn.us
    Fri May 22 11:22:45 EDT 2009
SWEET…..Now that makes perfect sense because I have been struggling with the select and zoom to issues not highlighting…
Thanks Dan  and Nelson for the extra set of eyes….
Have a great weekend…..
Thanks Again
Sent: Friday, May 22, 2009 9:53 AM
To: Jay Kapalczynski; Nelson Soto; geomoose-users at lists.sourceforge.net; geomoose-developers at lists.sourceforge.net
Subject: Re: [Geomoose-users] [Geomoose-developers] Buffer Problems
If you're getting that error, I doubt it is a problem with the Javascript.
Remove the "FILTER" lines in select.map, those are for an item query and causing you to have a no-match situation.
From: Jay Kapalczynski <jkapalczynski at ci.maple-grove.mn.us>
To: Nelson Soto <NSoto at plotplans.com>; "geomoose-users at lists.sourceforge.net" <geomoose-users at lists.sourceforge.net>; "geomoose-developers at lists.sourceforge.net" <geomoose-developers at lists.sourceforge.net>
Sent: Friday, May 22, 2009 9:45:03 AM
I don’t think that it can be the 1.6 version as I have been using that for some time…with select/buffer success…although it very well might be
I cant think of anything else that I changed…as I said I haven’t worked on this in a few months…the last I know it has been working
That and I haven’t done anything with the Select tools…
As a simple test I created a new Select…Still not working…
Is there some code that I am missing to set up a new select?  I think this is all that has to be written for the select to work
Could one of the .js files be corrupt?
Thanks
Maplegrove_demo.xml
<service title="Select Feature Poly" default="true" locked="true" cursor="url(cursors/select.cur), auto" shape="measurearea" type="inspect-search" icon="shared/images/toolbar/MapleGrove_Buttons/Select.jpg" highlight="shared/images/toolbar/MapleGrove_Buttons/Select.jpg">
                <url>php/select.php</url>
                <input type="multipoint" name="coords"/>
                <input type="hidden" name="shape" value="poly"/>
                <input type="hidden" name="map" value="/ms4w/apps/GeoMOOSE/Maple_Grove_GeoMoose/select.map"/>
                <input type="hidden" name="select" value="/ms4w/apps/GeoMOOSE/Maple_Grove_GeoMoose/select.map"/>
                <input type="select" name="layer" title="Layer to Select:">
                                <option value="Parcels:PID">Parcels</option>
                                <option value="Plats:PLAT_ID">Plats</option>
                                <option value="Parcel_Points:PID_NO">Parcel Points</option>
                </input>
                <input type="hidden" name="output" value="html"/>
</service>
Select.map file
LAYER # Parcels Polygon Layer
                    NAME 'Parcels'
                    DATA 'parcels/parcels.shp'
                    STATUS ON
                    TYPE POLYGON
    FILTERITEM 'PID'
                    FILTER /^%id%/
                    METADATA
                                qstring_validation_pattern '.'
                     END
                    HEADER 'parcels/select_header.html'
                    TEMPLATE 'parcels/select_parcel.html'
                    FOOTER 'parcels/select_footer.html'
                    TOLERANCE 0
                                CLASS
                                SYMBOL 'plainline'
                                SIZE 3
                                COLOR -1 -1 -1
                                OUTLINECOLOR 255 255 0
                                END
  END
Select_parcel.html file
<tr>
<td><b>PID:</b></td>
<td>[PID]</td>
</tr>
<tr>
<td colspan="2"><hr/></td>
</tr>
Sent: Friday, May 22, 2009 9:15 AM
To: Jay Kapalczynski; geomoose-users at lists.sourceforge.net; geomoose-developers at lists.sourceforge.net
Subject: RE: [Geomoose-developers] Buffer Problems
There are intermittent issues with GM 1.6 is you are using that. I don’t know if they would be related to this, but I’d highly recommend porting your work to GM 2 and give that a shot.
From: Jay Kapalczynski [mailto:jkapalczynski at ci.maple-grove.mn.us]
Sent: Friday, May 22, 2009 10:10 AM
To: geomoose-users at lists.sourceforge.net; geomoose-developers at lists.sourceforge.net
Subject: [Geomoose-developers] Buffer Problems
I have had this app running for some time now.  I haven’t touched anything in a few months.
I went back in and tried to do a buffer by line and am getting errors…I tried this on the other select buttons and the same error.
Nothing changed in my:
•         Maple Grove_demo.xml
•         Select.map
•         Buffer_select.map
Why all of a sudden does the query not find the parcels?
Any thoughts?
FIREFOX:
<br />
<b>Warning</b>:  [MapServer Error]: msQueryByShape(): No matching record(s) found.
 in <b>C:\ms4w\apps\GeoMOOSE\htdocs\php\buffer_select.php</b> on line <b>139</b><br />
<html><head><title>Mailing Label Service Error</title></head><body><h3>Service Message</h3><b style='color
:red'>Query Failed to return any results!</b></body></html>
LINE 139:
# Perform the Query.
$queryResultCheck = $queryMap->queryByShape($shape);
if($queryResultCheck == MS_FAILURE) {                            # If the query fails, error out.
                # Check to see if the Map has any pointers to an empty file
                $empty = $queryMap->web->empty;
                # If it's set then show that HTML instead. :D
                if(isset($empty) and $empty != '') {
                                readfile($empty);
                                exit(0);
                } else {
                                appError('Query Failed to return any results!');
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20090522/9be38716/attachment.html
More information about the Geomoose-users
