[Geomoose-users] Info from Select to a new window?
Brian Fischer bfischer at houstoneng.com
Thu May 28 14:43:20 EDT 2009
Brent,
This use to work, but haven't tried it in a while.  You could set the display attribute of the service tag to display="window" and it would pop the results up in a new window.  Give that a try.  Here is the documentation we wrote on it:
http://www.geomoose.org/moose/index.php?option=com_content&task=view&id=14&Itemid=29 Look at the display attribute under <service> section.
Also I had Dan write a little custom feature for me to create a link to open the results tab up in a new window so users could print it.  I think he mainly did it with some JavaScript and CSS.  Here is the app that is doing that. http://klamathcounty.houstoneng.com/klamathmap/klamathmap.html Select some parcels with the mailing labels tool or Identify tool then click on the "Print Info. Tab" in the menubar.
Hope this helps,
Brian
Brian Fischer, CFM  GIS Project Manager
Houston Engineering, Inc.
Phone: W: 763.493.4522 / M: 763.229.2734
-----Original Message-----
From: Brent Fraser [mailto:bfraser at geoanalytic.com]
Sent: Thursday, May 28, 2009 11:36 AM
To: Dan Little
Cc: GeoMOOSE Users List
Subject: Re: [Geomoose-users] Info from Select to a new window?
Dan,
 I'm using V1.6.1.
It looks like the target of the html/text generated by select.php is set around line 488 in ServiceManager.js (of course I could be totally out-to-lunch as my JavaScript is weak):
	} else if(returnType.match(/text/i) || contentType.match(/plain/i)){ // Plain Text Return
		var results = document.getElementById('content_results_form');
		var text = http.responseText;
		if(!(text.match(/\<html/))) {
			text = text.replace(/\n/g,'<br/>\n');
			text = '<tt>'+text+'</tt>';
		results.innerHTML = text;
		EventManager.triggerEvent('changetab',TABS_RESULTS_NAME);
	} else if(returnType.match(/csv/i) || contentType.match(/csv/i)) { // CSV return type
perhaps if do something like:
		var win = window.open("", "Results", "width=100, height=100, scrollbars=yes" );
		var results2 = win.document.body;
		results2.innerHTML = text;
Any thoughts on that?
Thanks!
Brent
Dan Little wrote:
> 1.6 or 2.0?
> ----- Original Message ----
>> From: Brent Fraser <bfraser at geoanalytic.com>
>> To: GeoMOOSE Users List <geomoose-users at lists.sourceforge.net>
>> Sent: Wednesday, May 27, 2009 11:35:08 AM
>> Subject: [Geomoose-users] Info from Select to a new window?
>> I'd like to send the attribute information of my selected features to a new
>> browser window instead of the Information tab.  What's a good way to do this?
>> Thanks!
>> Brent Fraser
>> Register Now for Creativity and Technology (CaT), June 3rd, NYC. CaT
>> is a gathering of tech-side developers & brand creativity professionals. Meet
>> the minds behind Google Creative Lab, Visual Complexity, Processing, &
>> iPhoneDevCamp as they present alongside digital heavyweights like Barbarian
>> Group, R/GA, & Big Spaceship. http://p.sf.net/sfu/creativitycat-com
>> Geomoose-users mailing list
>> Geomoose-users at lists.sourceforge.net
>> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
