[Geomoose-users] Curved labels and libgd or gd.
Brent Fraser bfraser at geoanalytic.com
Tue Nov 24 11:11:16 EST 2009
Did the labels appear at all? Were they only horizontal?  I'm not sure what you
mean by "like it should".  The ANGLE FOLLOW setting was originally intended for
labeling along road segments; it currently does a poor job of labeling streams
with lots of twists and turns.  And there are a few issues filed against it in
Maperver's Trac.
As for the loading of DLLs by mapserv.exe, a good tool to use is ProcessMonitor
(http://technet.microsoft.com/en-us/sysinternals/bb896645.aspx).  Run it on the
server when you do a pan or zoom to see which DLLs mapserv.exe is try to load.
Best regards,
Brent Fraser
FRANZ OKYERE wrote:
> Its  worked alright, the op system didn't show any errors and angle
> follow does not curve my labels like it should. But I suspect there's
> something wrong with my windows installation such that certain dlls
> can't be accessed on the expected path? I may be wrong but I wish
> it  were working, seriously.  Franz Okyere. GIS specialist
>> Date: Tue, 24 Nov 2009 07:45:39 -0700
>> From: bfraser at geoanalytic.com
>> To: franzzoa at hotmail.com
>> CC: geomoose-users at lists.sourceforge.net
>> Subject: Re: [Geomoose-users] Curved labels and libgd or gd.
>> You left out the "-o". The command should be:
>> Brent
>> FRANZ OKYERE wrote:
>>  > Hi all,
>>  > Its it a behaviour for the shp2img to produce some weird characters a@
>>  > command prompt when I type
>>  > or is there a problem with my syntax? Cheers
>>  > Franz Okyere
>>  > GIS Specialist
>>  >> Date: Mon, 23 Nov 2009 18:01:48 -0700
>>  >> Try copying shp2img into the cgi-bin dir and run it from the command
> line
>>  >> > When I try to run shp2img an error message which says libmap.dll is
>>  >> > missing shows up, but thats not true- libmap.dll exists in
>>  > apache/cgi-bin.
>>  >> > I guess may need to reinstall? Cheers.
>>  >> >> Date: Mon, 23 Nov 2009 14:20:02 -0700
>>  >> >> Yikes! That usually means mapserver crashed. Try using the
> mapserver's
>>  >> >> shp2img.exe on the command line with your map file to see if the
>>  >> >> operating
>>  >> >> system gives any more information (like missing DLLs).
>>  >> >> > I've managed to check both error reports but the message in them is
>>  >> >> not
>>  >> >> > specific. Eg- from the mozilla tools, internal server error,
> and from
>>  >> >> use
>>  >> >> > error log, premature end of script headers (not sure what this
> means
>>  >> >> > though). Any ideas why my label will not follow the line direction?
>>  >> >> > Thanks.
>>  >> >> > Date: Mon, 23 Nov 2009 08:37:57 -0800
>>  >> >> > From: danlittle at yahoo.com
>>  >> >> > To: franzzoa at hotmail.com; geomoose-users at lists.sourceforge.net
>>  >> >> > I find using Firefox's "Tools" -> "page Info" menu then looking
>>  > in the
>>  >> >> > media tab to be the easiest way to go.
>>  >> >> > You'll scroll down the list until you see the URL that refers
> to the
>>  >> >> image
>>  >> >> > (which should be in italics to indicate it is "broken"), then
>>  > copy the
>>  >> >> url
>>  >> >> > and open it up in a new tab/window.
>>  >> >> > From: FRANZ OKYERE <franzzoa at hotmail.com>
>>  >> >> > To: geomoose-users at lists.sourceforge.net
>>  >> >> > Sent: Mon, November 23, 2009 7:07:46 AM
>>  >> >> > I'll try that and see how it goes. Thanks.
>>  >> >> >> Date: Sun, 22 Nov 2009 20:43:50 -0700
>>  >> >> >> That means Mapserver is not sending back an image (but is likely
>>  >> >> sending
>>  >> >> >> back an error message). You could turn set DEBUG 5 in the
> LAYER (and
>>  >> >> >> you'll likely need to set the MAP's CONFIG MS_ERRORFILE
>>  >> >> >> "\ms4w\tmp\mserror.txt") to see if it reports a error. Or you
> could
>>  >> >> use
>>  >> >> >> an HTTP sniffer like smartsniff to view the conversation between
>>  >> >> >> Geomoose
>>  >> >> >> and mapserver.
>>  >> >> >> Brent
>>  >> >> >> > Yes I use vera_sans which happens to be in the fontset.list but
>>  >> >> then
>>  >> >> >> the
>>  >> >> >> > background goes pinkish, you know.
>>  >> >> >> >> Date: Sun, 22 Nov 2009 14:44:27 -0700
>>  >> >> > >> Subject: RE: [Geomoose-users] Curved labels and libgd or gd.
>>  >> >> >> >> Sounds like the problem is with TrueType fonts. What do you
>>  >> >> specify
>>  >> >> >> for
>>  >> >> >> >> the font name? Is it in the fonts\fontset.list? What is
> your MAP
>>  >> >> >> >> FONTSET pointing to?
>>  >> >> >> >> > Yes Brent Here is portion of my map file that is supposed
> to do
>>  >> >> the
>>  >> >> >> >> lines
>>  >> >> >> >> > and the labels. The shapefile is of a line type.
>>  >> >> >> >> > LAYER
>>  >> >> >> >> > NAME 'demoroads2'
>>  >> >> >> >> > TYPE LINE
>>  >> >> >> >> > DATA
>>  >> >> >> 'C:\ms4w\apps\geomoose2\maps\demo\countydata\demoroads.shp'
>>  >> >> >> >> > METADATA
>>  >> >> >> >> > 'wms_title' 'demoroads'
>>  >> >> >> >> > END
>>  >> >> > >> > STATUS DEFAULT
>>  >> >> >> >> > TRANSPARENCY 100
>>  >> >> >> >> > PROJECTION
>>  >> >> >> >> > 'proj=longlat'
>>  >> >> >> >> > 'ellps=WGS84'
>>  >> >> >> >> > 'datum=WGS84'
>>  >> >> >> >> > 'no_defs'
>>  >> >> >> >> > END
>>  >> >> >> >> > CLASS
>>  >> >> >> >> > EXPRESSION ('[ROADCLASS]' eq 'C')
>>  >> >> >> >> > STYLE
>>  >> >> >> >> > COLOR 255 0 0
>>  >> >> >> >> > SYMBOL 'plainline'
>>  >> >> >> >> > SIZE 2
>>  >> >> >> >> > MINSIZE 1
>>  >> >> >> >> > MAXSIZE 4
>>  >> >> >> >> > END
>>  >> >> >> >> > END
>>  >> >> >> >> > END
>>  >> >> >> >> > #and then I use an annotation layer to add the labels
>>  >> >> >> >> > LAYER # Road layer
>>  >> >> > NAME road_labels
>>  >> >> >> >> > DATA
>>  >> >> >> >> > STATUS ON
>>  >> >> >> >> > TYPE annotation
>>  >> >> >> >> > MAXSCALEDENOM 2834
>>  >> >> >> >> > MINSCALEDENOM 1400
>>  >> >> >> >> > LABELITEM 'ROAD_NAME'
>>  >> >> >> >> > LABELCACHE ON
>>  >> >> >> >> > CLASS
>>  >> >> >> >> > LABEL
>>  >> >> >> >> > COLOR 144 250 0
>>  >> >> >> >> > BUFFER 4
>>  >> >> >> >> > ANGLE AUTO
>>  >> >> >> >> > END
>>  >> >> >> >> > END
>>  >> >> >> >> > END # End of Road layer
>>  >> >> >> >> > Now,
>>  >> >> >> >> > the above works fine and shows the lines and labels but
> once I
>>  >> >> add
>>  >> >> >> >> > ANGLE FOLLOW
>>  >> >> > and/or TYPE TRUETYPE everything disappears. So what can I
>>  >> >> >> >> > do to see the labels whowing and following the line
> direction?
>>  >> >> >> >> > Cheers.
>>  >> >> >> >> > Franz Okyere.
>>  >> >> >> >> > GIS Specialist
>>  >> >> >> >> >> Date: Sun, 22 Nov 2009 11:36:55 -0700
>>  >> >> >> >> >> libgd is not important to ANGLE FOLLOW (at least not
> that I'm
>>  >> >> >> aware
>>  >> >> >> >> of).
>>  >> >> >> >> >> Are your labels using a
>>  >> >> > TrueType font (not bitmapped)? When you say
>>  >> >> >> >> >> they
>>  >> >> >> >> >> don't align, does that mean they are only horizontal?
> Are the
>>  >> >> >> layers
>>  >> >> >> >> >> you
>>  >> >> >> >> >> are trying to label TYPE LINE?
>>  >> >> >> >> >> Best Regards,
>>  >> >> >> >> >> Brent Fraser
>>  >> >> >> >> >> > Hi All, I need to find out whether I have libgd with my
>>  >> >> >> mapserver
>>  >> >> >> >> >> > installation- I'm using gm2 on ms2.3.1. as my labels don't
>>  >> >> align
>>  >> >> >> >> with
>>  >> >> >> >> >> my
>>  >> >> >> >> >> > line feature even after I have used angle follow in my
>>  >> >> mapfile.
>>  >> >> >> >> I've
>>  >> >> >> >> >> > downloaded the gd-2.0.33-1 binaries but honestly i'm not
>>  > sure
>>  >> >> >> what
>>  >> >> >> >> i'm
>>  >> >> >> >> >> > doing with them. Can anyone help! Thanks. Franz Okyere.
>>  >> >> > GIS
>>  >> >> >> >> >> SPECIALIST.
>>  > _________________________________________________________________
>>  >> >> >> >> >> > Got more than one Hotmail account? Save time by
> linking them
>>  >> >> >> >> together
>>  >> >> >> >> >> > http://clk.atdmt.com/UKM/go/186394591/direct/01/
>>  >> >> >> >> >> > Let Crystal Reports handle the reporting - Free Crystal
>>  >> >> Reports
>>  >> >> >> >> 2008
>>  >> >> >> >> >> > 30-Day
>>  >> >> >> >> >> > trial. Simplify your report design, integration and
>>  >> >> deployment -
>>  >> >> >> >> and
>>  >> >> >> >> >> focus
>>  >> >> >> >> >> > on
>>  >> >> >> >> >> > what you do best, core
>>  >> >> > application coding. Discover what's new with
>>  >> >> >> >> >> > Crystal Reports now. http://p.sf.net/sfu/bobj-july
>>  >> >> >> >> >> > Geomoose-users mailing list
>>  >> >> >> >> >> > Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
>>  >> >> >> >> > Use Hotmail to send and receive mail from your different
> email
>>  >> >> >> >> accounts
>>  >> >> >> >> > http://clk.atdmt.com/UKM/go/186394592/direct/01/
>>  >> >> >> > Got more than one Hotmail account? Save time by linking them
>>  >> >> together
>>  >> >> >> > Let Crystal Reports handle the reporting - Free Crystal Reports
>>  >> >> 2008
>>  >> >> >> > 30-Day
>>  >> >> >> > trial. Simplify your report design, integration and deployment -
>>  >> >> and
>>  >> >> >> focus
>>  >> >> >> > on
>>  >> >> >> > what you do best, core application coding. Discover what's new
>>  > with
>>  >> >> > View your other email accounts from your Hotmail inbox. Add
> them now.
>>  >> >> > Use Hotmail to send and receive mail from your different email
>>  >> >> accounts
> 2008
>>  >> >> > 30-Day
> - and
>>  >> >> focus
>>  >> >> > on
>>  >> >> > what you do best, core application coding. Discover what's new with
>>  >> > Have more than one Hotmail account? Link them together to easily
> access
>>  >> > both
>>  >> > Let Crystal Reports handle the reporting - Free Crystal Reports 2008
>>  >> > 30-Day
>>  >> > trial. Simplify your report design, integration and deployment - and
>>  > focus
>>  >> > on
>>  > New! Receive and respond to mail from other email accounts from within
>>  > Hotmail Find out how. <http://clk.atdmt.com/UKM/go/186394593/direct/01/ >
> View your other email accounts from your Hotmail inbox. Add them now.
> <http://clk.atdmt.com/UKM/go/186394592/direct/01/>
> Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
> trial. Simplify your report design, integration and deployment - and focus on
More information about the Geomoose-users mailing list
