[Geomoose-users] Reading font.list to use Truetype
Brent Fraser bfraser at geoanalytic.com
Fri Nov 27 12:52:53 EST 2009
Personally I doubt if it is a file permissions problem.  More than likely is it
a path name problem.  Run Process Monitor
(http://technet.microsoft.com/en-us/sysinternals/bb896645.aspx) on the server to
see the paths to the files mapserver (or php) is trying to open.
   Or perhaps the error message is misleading and there is a syntax problem
inside fontset.list.
FRANZ OKYERE wrote:
> I've changed that-was a typo. The problem still exist. The question is
> how do I set file access to read the file? Obviously the font file is
> not being read.
>> Date: Fri, 27 Nov 2009 09:45:54 -0700
>> From: bfraser at geoanalytic.com
>> To: franzzoa at hotmail.com
>> CC: geomoose-users at lists.sourceforge.net
>> Subject: Re: [Geomoose-users] Reading font.list to use Truetype
>> Usually it is called fontset.list (not .lists), or if you have an older
>> mapserver installation, fonts.list.
>> FRANZ OKYERE wrote:
>>  > Hi in my efforts to get implement my curved labels I have also
>>  > discovered the following error even after reinstallation: msLoadFont():
>>  > Unable to access file. Error opening fontset
>>  > ..\.\fonts\font.lists. Any ideas as to what is giving this error,
>>  > because its the cause of my woes. The path to the fontset file is
>>  > perfect though. Franz Okyere. GIS specialist.
>>  > View your other email accounts from your Hotmail inbox. Add them now.
>>  > <http://clk.atdmt.com/UKM/go/186394592/direct/01/>
>>  > Let Crystal Reports handle the reporting - Free Crystal Reports 2008
> 30-Day
>>  > trial. Simplify your report design, integration and deployment - and
> focus on
>>  > what you do best, core application coding. Discover what's new with
>>  > Crystal Reports now. http://p.sf.net/sfu/bobj-july
>>  > _______________________________________________
>>  > Geomoose-users mailing list
>>  > Geomoose-users at lists.sourceforge.net
>>  > https://lists.sourceforge.net/lists/listinfo/geomoose-users
> Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
> trial. Simplify your report design, integration and deployment - and focus on
More information about the Geomoose-users mailing list
