[Geomoose-users] Using a different projection
Dan Little danlittle at yahoo.com
Fri Oct 2 21:14:06 EDT 2009
http://www.spatialreference.org will give you the Proj4JS string I believe.
>From: Brian Fischer <bfischer at houstoneng.com>
>To: "Edward E. Boesenberg, III" <eboesenberg at niraengineers.com>; "geomoose-users at lists.sourceforge.net" <geomoose-users at lists.sourceforge.net>
>Sent: Friday, October 2, 2009 4:44:43 PM
>Subject: Re: [Geomoose-users] Using a different projection
>Ed,
>You need to create a Proj4js
>definition and then reference it in geomoose.html.  See the instructions at http://www.geomoose.org/moose/docs/projections.html
>Brian
>Fischer,CFM
>GIS Project Manager
>Houston Engineering, Inc.
>>Phone: W: 763.493.4522 / M: 763.229.2734
>From:Edward E.
>Boesenberg, III [mailto:eboesenberg at niraengineers.com]
>Sent: Friday, October 02, 2009 3:56 PM
>To: geomoose-users at lists.sourceforge.net
>Subject: [Geomoose-users] Using a different projection
>I just installed GM 2.0 and have it up and running.  I
>would like to specify a different projection (EPSG: 15354).  Do I need to
>create the javascript file with the formula or will GM recognize my EPSG code?
>Thanks
>Ed
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20091002/73c55f34/attachment.html
More information about the Geomoose-users mailing list
