[Geomoose-users] Printing quality
t faustino geomatrix3d at gmail.com
Mon Oct 5 08:38:48 EDT 2009
Searched through the forums but didn't find a solution;
I am sendng a print of my map search results but they only seem to
print in low quality; I had a look at printpdf2 and tried adjusting
this line;
/output file
	$pdf->SetTitle('GeoMOOSE');
	renderImage($xml, $outputPdf.'.jpeg', $mapwidth*$quality*100,
$mapheight*$quality*100,
		$extent[0], $extent[1], $extent[2], $extent[3], $quality);
	$pdf->Image($outputPdf.'.jpeg',.45,.70,$mapwidth,$mapheight);
	$pdf->Output($outputPdf.'.pdf');
from quality 72 to 100 but no change in quality. Can someone provide
some guidance regarding this?
My aerial is a highres .sid file - so can only assume at this point
that due to rendering to .jpeg the quality is what it is.
Thanks!
"If one advances confidently in the direction of his dreams, and
endeavors to live the life which he has imagined, he will meet with a
success unexpected in common hours."  ~Thoreau
More information about the Geomoose-users mailing list
