[Geomoose-users] Problem adding a layer
Len Kne lkne at houstoneng.com
Mon Oct 5 15:44:46 EDT 2009
Edward
If the demo layers work, then "mapserver_url" is set correct in the mapbook, which would point towards path problems in the map file.  Another issue could be extents in either the mapbook or map file.
A real helpful tool for trouble shooting is Firebug in the Firefox browser.  Using firebug, you can isolate the GET call to the server - I like to copy the URL GeoMOOSE is sending and run it directly from the browser - this way you will see MapServer errors.
Len
From: Edward E. Boesenberg, III [mailto:eboesenberg at niraengineers.com]
Sent: Monday, October 05, 2009 12:52 PM
To: Geomoose Support
Subject: [Geomoose-users] Problem adding a layer
I just installed a new server and Geomoose 2.0 and I am trying to add a layer but I am having problems. I reprojected all my data to EPSG 2915 so there is no projection error.
I included below snippets from my mapbook and mapfile.  Does anybody see what's wrong?
<map-source name="muni_bndy" type="mapserver">
                                <file>./demo/muni_bndy/muni_bndy.map</file>
                                <layer name="all"/>
                </map-source>
                <layer title="muni_bndy" src="muni_bndy/all" status="on" legend="true"/>
Here is my mapfile:
MAP
                NAME 'muni_bndy'
                SIZE 800 650
                STATUS ON
                EXTENT  457272 4215829 1688276 5254002
        UNITS METERS
                INCLUDE "../../geomoose_globals.map"
                WEB
                                INCLUDE "../../temp_directory.map"
                END
                LEGEND
                      STATUS ON
                      LABEL
                                TYPE TRUETYPE
                                FONT vera_sans
                                SIZE 8
                                COLOR 0 0 0
                      END
                END
#    CONFIG PROJ_LIB "/ms4w/proj/nad"
    Projection
                "init=epsg:26915"   # UTM Zone 15N
    END
LAYER
                NAME 'muni_bndy'
                DATA '//Nira-server/ms4w/apps/geomoose2/maps/demo/muni_bndy/muni_bndy.shp'
                TYPE LINE
                STATUS ON
                CLASS
                  NAME 'muni_bndy'
                  STYLE
                  COLOR 100 100 100
                END
                END
                MAXSCALE 1500000000
END ## Layer
END ## end Map
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20091005/06216cd0/attachment.html
More information about the Geomoose-users mailing list
