[Geomoose-users] Raster Imagery
Johnson, Jeremy JJohnson at ci.blaine.mn.us
Tue Oct 13 16:23:30 EDT 2009
The "init=epsg:99999" is a custom projection for Anoka County
Coordinates that I added to the epsg file.
When I do the ogrinfo command, I get the following:
FAILURE:  Unable to open the datasource
'/ms4/data/all_crimes_density1.tif' with the following drivers.
->ESRI Shapefile
->Mapinfo File
->UK .NTF
->SDTS
->Tiger
->S57
->DGN
->VRT
->REC
->MEMORY
->BNA
->CSV
->GML
->GPX
->KML
->GEOJSON
->GMT
->SQLITE
->ODBC
->PGEO
->POSTGRESQL
->MYSQL
->AVCBIN
I also did the same on the SID files I have in the same directory that I
show up just fine, and I received the same error
Jeremy Johnson, GISP
City of Blaine
-----Original Message-----
From: Brent Fraser [mailto:bfraser at geoanalytic.com]
Sent: Tuesday, October 13, 2009 3:03 PM
To: Johnson, Jeremy
Cc: geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] Raster Imagery
That  "init=epsg:99999" doesn't look right.  Can you do a ogrinfo on the
command line:
ogrinfo /ms4w/data/All_Crimes_Density1.tif
Best Regards,
Brent Fraser
> Nope.  That wasn't it. And yes, I am on 1.6.
> City of Blaine
> ________________________________
> From: Dan Little [mailto:danlittle at yahoo.com]
> Sent: Tuesday, October 13, 2009 2:28 PM
> To: Johnson, Jeremy; geomoose-users at lists.sourceforge.net
> If this is GeoMOOSE 1.6.X change STATUS to DEFAULT.
> 	From: "Johnson, Jeremy" <JJohnson at ci.blaine.mn.us>
> 	To: geomoose-users at lists.sourceforge.net
> 	Sent: Tue, October 13, 2009 1:43:06 PM
> 	Subject: [Geomoose-users] Raster Imagery
> 	I have created a crime density raster with Spatial Analyst and I
> want to have it display in Geomoose.  However, when I add it to my map
> and turn it on, it is just white.  I have attached a PDF showing my
> dilemma and a copy of the mapfile.  Any thoughts would be appreciated.
> 	PS - I purposely put the call to the map file under the street
> centerline and above everything else to show what happens when the
layer
> is activated.
> 	MAP
> 	      NAME 'crimedensity'
> 	      EXTENT  474400 4995000 494000 5007000
> 	      UNITS METERS
> 	      FONTSET '../fonts/fontset.list'
> 	      SYMBOLSET '../symbols/symbol.sym'
> 	      RESOLUTION 96
> 	      IMAGETYPE png
> 	      INTERLACE OFF
> 	      PROJECTION
> 	        "init=epsg:26915"
> 	      END
> 	      QUERYMAP
> 	            STATUS ON
> 	            STYLE SELECTED
> 	      END
> 	      WEB
> 	              INCLUDE "../temp_directory.map"
> 	      END
> 	LAYER
> 	  NAME crimedensity
> 	  DATA '/ms4w/data/All_Crimes_Density1.tif'
> 	  TYPE raster
> 	  STATUS ON
> 	  PROCESSING "BANDS=1,2,3"
> 	      PROJECTION
> 	          "init=epsg:99999"
> 	      END #PROJECTION
> 	END #LAYER
> 	END  #Map
> 	G.I.S. Coordinator
> 	City of Blaine
> 	10801 Town Square Dr Ne
> 	Blaine, MN   55449
> 	(763) 717-2639
> Come build with us! The BlackBerry(R) Developer Conference in SF, CA
> is the only developer event you need to attend this year. Jumpstart
your
> developing skills, take BlackBerry mobile applications to market and
stay
> ahead of the curve. Join us from November 9 - 12, 2009. Register now!
> http://p.sf.net/sfu/devconference
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
