[Geomoose-users] Raster Imagery
Johnson, Jeremy JJohnson at ci.blaine.mn.us
Tue Oct 13 16:38:03 EDT 2009
I did not, but I went ahead and did after your email:
	20          	(X Pixel size)
	0.000000
	0.000000
	-20			(Y Pixel size)
	499919.272469	(X left extreme)
	164048.732597	(Y top extreme)
Jeremy Johnson, GISP
City of Blaine
-----Original Message-----
Sent: Tuesday, October 13, 2009 3:25 PM
To: Johnson, Jeremy; bfraser at geoanalytic.com
Cc: geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] Raster Imagery
Do you have a tfw file defined?
----- Original Message ----
> From: "Johnson, Jeremy" <JJohnson at ci.blaine.mn.us>
> To: bfraser at geoanalytic.com
> Sent: Tue, October 13, 2009 3:23:30 PM
> The "init=epsg:99999" is a custom projection for Anoka County
> Coordinates that I added to the epsg file.
> When I do the ogrinfo command, I get the following:
> FAILURE:  Unable to open the datasource
> '/ms4/data/all_crimes_density1.tif' with the following drivers.
> ->ESRI Shapefile
> ->Mapinfo File
> ->UK .NTF
> ->SDTS
> ->Tiger
> ->S57
> ->DGN
> ->VRT
> ->REC
> ->MEMORY
> ->BNA
> ->CSV
> ->GML
> ->GPX
> ->KML
> ->GEOJSON
> ->GMT
> ->SQLITE
> ->ODBC
> ->PGEO
> ->POSTGRESQL
> ->MYSQL
> ->AVCBIN
> I also did the same on the SID files I have in the same directory that
I
> show up just fine, and I received the same error
> City of Blaine
> From: Brent Fraser [mailto:bfraser at geoanalytic.com]
> Sent: Tuesday, October 13, 2009 3:03 PM
> To: Johnson, Jeremy
> That  "init=epsg:99999" doesn't look right.  Can you do a ogrinfo on
the
> command line:
> ogrinfo /ms4w/data/All_Crimes_Density1.tif
> Best Regards,
> Brent Fraser
> > Nope.  That wasn't it. And yes, I am on 1.6.
> > City of Blaine
> > ________________________________
> > From: Dan Little [mailto:danlittle at yahoo.com]
> > Sent: Tuesday, October 13, 2009 2:28 PM
> > To: Johnson, Jeremy; geomoose-users at lists.sourceforge.net
> > If this is GeoMOOSE 1.6.X change STATUS to DEFAULT.
> >     To: geomoose-users at lists.sourceforge.net
> >     Sent: Tue, October 13, 2009 1:43:06 PM
> >     Subject: [Geomoose-users] Raster Imagery
> >     I have created a crime density raster with Spatial Analyst and I
> > want to have it display in Geomoose.  However, when I add it to my
map
> > and turn it on, it is just white.  I have attached a PDF showing my
> > dilemma and a copy of the mapfile.  Any thoughts would be
appreciated.
> >     PS - I purposely put the call to the map file under the street
> > centerline and above everything else to show what happens when the
> layer
> > is activated.
> >     MAP
> >           NAME 'crimedensity'
> >           EXTENT  474400 4995000 494000 5007000
> >           UNITS METERS
> >           FONTSET '../fonts/fontset.list'
> >           SYMBOLSET '../symbols/symbol.sym'
> >           RESOLUTION 96
> >           IMAGETYPE png
> >           INTERLACE OFF
> >           PROJECTION
> >             "init=epsg:26915"
> >           END
> >           QUERYMAP
> >                 STATUS ON
> >                 STYLE SELECTED
> >           END
> >           WEB
> >                   INCLUDE "../temp_directory.map"
> >           END
> >     LAYER
> >       NAME crimedensity
> >       DATA '/ms4w/data/All_Crimes_Density1.tif'
> >       TYPE raster
> >       STATUS ON
> >       PROCESSING "BANDS=1,2,3"
> >           PROJECTION
> >               "init=epsg:99999"
> >           END #PROJECTION
> >     END #LAYER
> >     END  #Map
> >     G.I.S. Coordinator
> >     City of Blaine
> >     10801 Town Square Dr Ne
> >     Blaine, MN   55449
> >     (763) 717-2639
> > Come build with us! The BlackBerry(R) Developer Conference in SF, CA
> > is the only developer event you need to attend this year. Jumpstart
> your
> > developing skills, take BlackBerry mobile applications to market and
> stay
> > ahead of the curve. Join us from November 9 - 12, 2009. Register
now!
> > http://p.sf.net/sfu/devconference
> > Geomoose-users mailing list
> > Geomoose-users at lists.sourceforge.net
> > https://lists.sourceforge.net/lists/listinfo/geomoose-users
your
stay
> ahead of the curve. Join us from November 9 - 12, 2009. Register now!
More information about the Geomoose-users mailing list
