[Geomoose-users] Zoom In Minimum Extent
Brian Fischer bfischer at houstoneng.com
Wed Oct 28 13:41:58 EDT 2009
Michael,
This is an important thing to recognize.  GM 2.x uses the map control from the OpenLayers library.  Openlayers uses a concept of setting up the map with discrete scales.  So each scale as Len pointed out in your mapbook represents a tick (scale) on the navigation slider tool.
With that said there is also a parameter you can add to the mapbook called fractional zooms. This will allow you to zoom to scales in between those discrete scales.  http://www.geomoose.org/moose/docs/configuration.html#fractional-zoom
Brian Fischer, CFM  GIS Project Manager
Houston Engineering, Inc.
Phone: W: 763.493.4522 / M: 763.229.2734
-----Original Message-----
Sent: Wednesday, October 28, 2009 11:57 AM
To: 'Michael Reynolds'; geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] Zoom In Minimum Extent
In the mapbook, <param name="scales"> can take decimal numbers, so you could set the first value to "0.5" (or less).  This create a new scale stop with a larger scale.
Len
From: Michael Reynolds [mailto:Mike.Reynolds at dot.state.mn.us]
Sent: Wednesday, October 28, 2009 11:52 AM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] Zoom In Minimum Extent
I'm looking for the configuration setting to adjust the minimum geomoose2.x will zoom in.
Previous geomoose version allowed a very small scale.  New version seems limited to 1:1417.  Seems like the geomoose 2.x scale drop down won't let me select anything below this value.
Ideas?
Come build with us! The BlackBerry(R) Developer Conference in SF, CA
is the only developer event you need to attend this year. Jumpstart your
developing skills, take BlackBerry mobile applications to market and stay
ahead of the curve. Join us from November 9 - 12, 2009. Register now!
http://p.sf.net/sfu/devconference
Geomoose-users mailing list
Geomoose-users at lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
