[Geomoose-users] Web Mercator
Len Kne lkne at houstoneng.com
Tue Apr 6 08:32:15 EDT 2010
Heather
You will want to change the layer type to "mapserver", this will access the data via mapscript instead of making a WMS call to get the data.  If that doesn't fix it, the pink screen usually means that there is an error in the mapfile.  You can track down the problem in Firefox by going to Tools >> Page Info and selecting the media tab.  Find the address that calls the layer in question and copy that address into another Firefox tab and call it.  This should give you an error message to help track down the problem.
Len
From: Heather Wirth [mailto:HWIRTH at co.benton.mn.us]
Sent: Tuesday, April 06, 2010 7:16 AM
To: Len Kne; geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] Web Mercator
We re-projected the parcel layer that comes with the web mercator download, hoping that if we could get the demo layer to work, we could add other layers.  After making that change, changing the extent in the mapfile (to the "zoom to parcel data" extent from the mapbook), and removing any reference to EPSG 26915 (also tried changing those references to 900913) all we get is the pink screen.
Are we missing something easy?
Also, we noticed in the mapbook's map-source that the parcel layer type is wms; is there a reason to not use the mapserver type?
Thanks for your help.
Heather
>>> Len Kne <lkne at houstoneng.com> 4/5/2010 1:11 PM >>>
Hi Heather
The web Mercator demo re-projects the county boundaries on the client side (that is with GeoMOOSE using OpenLayers).  I've not seen good results re-projecting on the client and can recommend two options:
1.       Re-project the layers will use in GeoMOOSE to the web Mercator projection (in Arc, it is web Mercator (auxiliary sphere)).  This will give the best performance as the layers will not have to be re-projected every time there is a map redraw.
2.       Do the re-projection in the map file.
Len
Sent: Monday, April 05, 2010 12:57 PM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] Web Mercator
We are just starting to look at the web mercator download and demo, and noticed that there seems to be a problem with how everything lines up.  For instance, if I use the "Jump To" to zoom to the full state of MN, the counties do not line up properly.  Is there a fix for this?  Any help would be much appreciated.
Heather
Heather Wirth
Benton County GIS Specialist
7752 Highway 25 NE, PO Box 247
Foley, MN 56329
Phone: 320-968-5168
Fax: 320-968-5333
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100406/68b62be2/attachment.html
More information about the Geomoose-users mailing list
