[Geomoose-users] Map Layer Order
Len Kne lkne at houstoneng.com
Fri Apr 30 13:21:22 EDT 2010
Hi Dave
Try moving MH below the sewer line layer in the MAP file.  Normally GeoMOOSE will order layers in the same order as the <map-source>, but when more than one layer in a map-source point to the same MAP file, the order is controlled by the MAP file, which is first in first out.
Len
From: Dave Misun [mailto:dmisun at kapur-assoc.com]
Sent: Friday, April 30, 2010 11:02 AM
To: 'geomoose-users at lists.sourceforge.net'
Subject: [Geomoose-users] Map Layer Order
Hello Everyone,
I have a question about layer order on a map, searched the user list and didn't find any previous threads covering this. I have a sewer manhole point layer and a sewer pipe line layer, among others on my map, and the line layer is rendering on top of the point layer. I have the point layer on top of the list in the catalog & map service sections of MAPBOOK, as well as having MH come before pipes in my MAP file, but the pipes continue to render on top of the MHs; all else is correct. What am I overlooking?
I'm using GM 2.2.
Any advice is appreciated. Thanks!
Dave Misun
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100430/1fb3b893/attachment.html
More information about the Geomoose-users mailing list
