[Geomoose-users] GeoMoose v1.6 Linux
Dan Little danlittle at yahoo.com
Tue Aug 17 10:09:48 EDT 2010
Have you tried to run the request from the command line to see if you are
getting a seg fault?
Is there anything useful in the Apache Error Log?
>From: t faustino <geomatrix3d at gmail.com>
>To: geomoose-users at lists.sourceforge.net
>Sent: Mon, August 16, 2010 8:55:34 AM
>Subject: [Geomoose-users] GeoMoose v1.6 Linux
>Folks,
>Need some help with some troubleshooting ideas regarding my one last error:
>No element found.
This occurs when trying to select a parcel that has rendered to map via my
parcels.map. The parcels are being drawn directly from database via connectype
postgis.
When trying to select parcel - the map just hangs indefinately.
Any ideas would be appreciated.
"If one advances confidently in the direction of his dreams, and endeavors to
live the life which he has imagined, he will meet with a success unexpected in
common hours."  ~Thoreau
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100817/9e0c2933/attachment.html
More information about the Geomoose-users mailing list
