[Geomoose-users] msPostGISLayerWhichShapes error
Dan Little danlittle at yahoo.com
Tue Aug 17 10:45:08 EDT 2010
Remove the FILTERITEM, then I'd try FILTER "upper(parcel_no) like
'%'||upper('%id%')||'%'"
>From: t faustino <geomatrix3d at gmail.com>
>To: geomoose-users at lists.sourceforge.net
>Sent: Mon, August 2, 2010 9:23:50 AM
>Subject: [Geomoose-users] msPostGISLayerWhichShapes error
>OS: linux
>Geomoose v1.6
>When trying a search I'm getting this msPostGISLayerWhichShapes error result
>from itemquery.map;
>Did a search query against my parcels layer on parcel # 059;
>msPostGISLayerWhichShapes(): Query error. Error (ERROR: syntax error at or near
>"^" LINE 1: ...9454.261772,2143616.71123 1209454.261772))',2240) and (^059) ^ )
>>executing query: select
>>"gid","map_no","dist","parcel_no","subpar","Par_id","Comments","Shape_Leng","Shape_Area","Rkey",encode(AsBinary(force_collection
>>(force_2d("the_geom")),'NDR'),'hex') as geom,"gid" from "parcels" where the_geom
>>&& GeomFromText('POLYGON((2143616.71123 1209454.261772,2143616.71123
>>1255434.854927,2200833.463198 1255434.854927,2200833.463198
>>1209454.261772,2143616.71123 1209454.261772))',2240) and (^059)
  Appears to not like the FILTER syntax;
Itemquery.map:
>LAYER # Parcels Polygon Layer
>        NAME 'parcels'
>        CONNECTIONTYPE postgis
>        CONNECTION "dbname='*****' host=localhost port=5432 user='*****'
>password='*****' sslmode=prefer"
>        DATA '"the_geom" FROM "parcels" using unique gid using srid=2240'
>        STATUS DEFAULT
>        TYPE POLYGON
>        METADATA
>            qstring_validation_pattern '.'
>        END
>        TEMPLATE 'landrecords/itemquery_parcels.html'
>        FILTERITEM 'parcel_no'
>        FILTER /.*%id%.*/i   #begins with search regular expression
>  END
Any advise anyone?
"If one advances confidently in the direction of his dreams, and endeavors to
live the life which he has imagined, he will meet with a success unexpected in
common hours."  ~Thoreau
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100817/647f74aa/attachment.html
More information about the Geomoose-users mailing list
