[Geomoose-users] No Element found error in GeoMoose.js
Brent Fraser bfraser at geoanalytic.com
Tue Aug 17 10:51:19 EDT 2010
Change your <service definition from
   <input type="hidden" name="layer" value="pinSearch"/>
to
   <input type="hidden" name="layer" value="Parcels"/>
(it should be the LAYER name in your map file)
And the FILTER should contain the database column name, "parcel_no".
Brent
t faustino wrote:
> Brent,
> As always, my thanks for your helpful response.
> Interestingly using your suggestion _FILTER 'parcel_no=%id%'_  I can see
> a layer=undefined&id=059. Much closer than I had before.
> I did try FILTER 'Parcels=%id%' with same results. So looks like you
> have again pointed me in the right direction.
> On Mon, Aug 16, 2010 at 4:17 PM, Brent Fraser <bfraser at geoanalytic.com
> <mailto:bfraser at geoanalytic.com>> wrote:
>     The JavaScript is waiting for a response from the server (the php)
>     and likely not getting one.  The server process is taking too long
>     (timing out?), or it is stopping unexpectedly (crashing?).
>     My technique in these cases is to put some print statements in the
>     PHP to see where it's failing.
>     But looking back at your previous emails of last week, it looks like
>     mapserver is not forming the SQL from the FILTER properly.  It gives
>      and (^059)
>     instead of something like
>      and (parcel_no=059)
>     How about using a filter of
>     Brent
>     t faustino wrote:
>         To add to my previous email;
>         The error seems to point to line 971 within the GeoMoose. js;
>            http.onreadystatechange=function (){if(http.readyState==4){var
>            results=null;....
>         Completely beyond me...Dan? Brent?
>         "If one advances confidently in the direction of his dreams, and
>         endeavors to live the life which he has imagined, he will meet
>         with a success unexpected in common hours."  ~Thoreau
>         This SF.net email is sponsored by
>         Make an app they can't live without
>         Enter the BlackBerry Developer Challenge
>         http://p.sf.net/sfu/RIM-dev2dev
>         _______________________________________________
>         Geomoose-users mailing list
>         Geomoose-users at lists.sourceforge.net
>         <mailto:Geomoose-users at lists.sourceforge.net>
>         https://lists.sourceforge.net/lists/listinfo/geomoose-users
> endeavors to live the life which he has imagined, he will meet with a
More information about the Geomoose-users mailing list
