[Geomoose-users] Need help with ELSE / OR statements
Dan Little danlittle at yahoo.com
Thu Aug 19 14:05:20 EDT 2010
Good news, GM2.2 can do this! :) Bad news... GM1.6 is harder and you need to use
manual SQL.
$clauses = array();
if($field == "TRS") {
 array_push($clauses, "TRS like '%".$searchval$."%'");
if($field2 == "DOCTYPE") {
 array_push($clauses, "DOCTYPE LIKE '".$searchval2."%'");
$all_clauses = implode(" or ", $clauses);
 $rs = $conn->Execute("SELECT * FROM Surveyor_Image_Link WHERE ".$all_clauses."
ORDER BY ".$sort." ASC");
>From: Jim Dahl <jim.dahl at mail.co.douglas.mn.us>
>To: geomoose-users at lists.sourceforge.net
>Sent: Thu, August 19, 2010 9:56:08 AM
>Subject: [Geomoose-users] Need help with ELSE / OR statements
>I am trying to add  two search fields in my GM app.  I can make each field
>search correctly by  themselves but not together.  I have the code where the
>first two lines  work and when I comment out the first two and enable the second
>two lines, the  code works for searchval2.  What I want to know is how can I use
>ELSE with  or without the OR statements to allow me to enable both fields for
>the  search?
>  if  ($field == "TRS") {
>    $rs = $conn->Execute("SELECT * FROM  Surveyor_Image_Link WHERE TRS LIKE
>'%".$searchval."%' ORDER BY ".$sort."  ASC");
>//  ) if ($field2 == "DOCTYPE") {
>//     $rs = $conn->Execute("SELECT * FROM Surveyor_Image_Link WHERE DOCTYPE
>LIKE  '".$searchval2."%' ORDER BY ".$sort." ASC");
>  } else  {
>    echo "You have reached this page by  mistake.";
>Jim Dahl, GISP
>GIS  Coordinator
>Douglas County Public Works
>526 Willow Dr
>PO Box  398
>Alexandria MN 56308
>V 320-762-2933
>   320-762-2999
>F  320-762-2998
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100819/ad7f899b/attachment.html
More information about the Geomoose-users mailing list
