[Geomoose-users] Need help with ELSE / OR statements
Dan Little danlittle at yahoo.com
Thu Aug 19 18:54:13 EDT 2010
Is this the old version of the script? It looks like it does not include the
code suggestion I made.
>From: Jim Dahl <jim.dahl at mail.co.douglas.mn.us>
>To: Dan Little <danlittle at yahoo.com>; geomoose-users at lists.sourceforge.net
>Sent: Thu, August 19, 2010 3:02:23 PM
>Subject: RE: [Geomoose-users] Need help with ELSE / OR statements
>Dan,  it must be getting close.  I had to take out a curly bracket } and a
>dollar sign $ to make it not error out but search came back empty.  I will
>include more script if that helps.
><?php
>$field=(isset($_REQUEST['field']))?$_REQUEST['field']:"none";
>$field2=(isset($_REQUEST['field2']))?$_REQUEST['field2']:"none";
>$sort=(isset($_REQUEST['sort']))?$_REQUEST['sort']:"Surveyor_Image_Link.TRS";
>//$sort2=(isset($_REQUEST['sort2']))?$_REQUEST['sort2']:"Surveyor_Image_Link.DOCTYPE";
>$searchval=(isset($_REQUEST['searchval']))?$_REQUEST['searchval']:"none";
>$searchval2=(isset($_REQUEST['searchval2']))?$_REQUEST['searchval2']:"none";
>if  ($field <> "none") {
>  // Microsoft Access connection  string.
>  // Douglas server
>  //$db =
>'\\ms4w\\apps\\GeoMOOSE\\douglas\\maps_douglas\\database\\parcels.mdb';
>  //  HEI server
>  $db =  '\\ms4w\\apps\\GeoMOOSE\\douglas\\maps_douglas\\database\\aex.mdb';
>  $conn = new COM('ADODB.Connection'); // or exit('Cannot  start ADO.');
>  // Two ways to connect. Choose  one.
>  $conn->Open("Provider=Microsoft.Jet.OLEDB.4.0; Data  Source=$db"); // or
>exit('Cannot open with  Jet.');
>  //$conn->Open("DRIVER={Microsoft Access Driver  (*.mdb)}; DBQ=$db"); // or
>exit('Cannot open with driver.');
>  // SQL statement to build recordset.
>  if  ($field == "TRS" || $field2 == "DOCTYPE") {
>    $rs =  $conn->Execute("SELECT * FROM Surveyor_Image_Link WHERE TRS LIKE
>'%".$searchval."%' ORDER BY ".$sort." ASC");
>//  ) elseif ($field2 == "DOCTYPE") {
>//     $rs = $conn->Execute("SELECT * FROM Surveyor_Image_Link WHERE DOCTYPE
>LIKE  '".$searchval2."%' ORDER BY ".$sort." ASC");
>  } else  {
>    echo "You have reached this page by  mistake.";
>-----Original Message-----
>>From: Dan Little    [mailto:danlittle at yahoo.com]
>>Sent: Thursday, August 19, 2010 1:05    PM
>>To: Jim Dahl;    geomoose-users at lists.sourceforge.net
>>Subject: Re: [Geomoose-users]    Need help with ELSE / OR statements
>>Good news, GM2.2 can do this! :) Bad news... GM1.6 is harder and you need    to
>>use manual SQL.
>>$clauses = array();
>>if($field == "TRS") {
>> array_push($clauses, "TRS like '%".$searchval$."%'");
>>if($field2 == "DOCTYPE") {
>> array_push($clauses, "DOCTYPE    LIKE '".$searchval2."%'");
>>$all_clauses = implode(" or ", $clauses);
>>".$all_clauses." ORDER BY ".$sort."    ASC");
>>>To: geomoose-users at lists.sourceforge.net
>>>Sent: Thu, August 19, 2010 9:56:08      AM
>>>Subject: [Geomoose-users] Need help with ELSE / OR statements
>>>I am trying to      add two search fields in my GM app.  I can make each field
>>>search      correctly by themselves but not together.  I have the code where the
>>>first two lines work and when I comment out the first two and enable the
>>>second two lines, the code works for searchval2.  What I want to know      is
>>>how can I use ELSE with or without the OR statements to allow me to      enable
>>>both fields for the search?
>>>  if      ($field == "TRS") {
>>>//  ) if ($field2 == "DOCTYPE")      {
>>>  } else {
>>>Jim Dahl, GISP
>>>GIS      Coordinator
>>>Douglas County Public Works
>>>526 Willow Dr
>>>PO Box      398
>>>Alexandria MN 56308
>>>V 320-762-2933
>>>   320-762-2999
>>>F      320-762-2998
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100819/07171d27/attachment.html
More information about the Geomoose-users mailing list
