[Geomoose-users] Need help with ELSE / OR statements
Jim Dahl jim.dahl at mail.co.douglas.mn.us
Fri Aug 20 14:40:22 EDT 2010
Thanks Dan!, with a few more adjustments, the biggest changing the
implode from OR to AND, it appears to be working.  Thanks very much.
jim
	-----Original Message-----
	Sent: Thursday, August 19, 2010 5:54 PM
	To: Jim Dahl; geomoose-users at lists.sourceforge.net
	Subject: Re: [Geomoose-users] Need help with ELSE / OR
statements
	Is this the old version of the script? It looks like it does not
include the code suggestion I made.
		To: Dan Little <danlittle at yahoo.com>;
		Sent: Thu, August 19, 2010 3:02:23 PM
		Subject: RE: [Geomoose-users] Need help with ELSE / OR
statements
		Dan, it must be getting close.  I had to take out a
curly bracket } and a dollar sign $ to make it not error out but search
came back empty.  I will include more script if that helps.
		<?php
$field=(isset($_REQUEST['field']))?$_REQUEST['field']:"none";
$field2=(isset($_REQUEST['field2']))?$_REQUEST['field2']:"none";
$sort=(isset($_REQUEST['sort']))?$_REQUEST['sort']:"Surveyor_Image_Link.
TRS";
//$sort2=(isset($_REQUEST['sort2']))?$_REQUEST['sort2']:"Surveyor_Image_
Link.DOCTYPE";
$searchval=(isset($_REQUEST['searchval']))?$_REQUEST['searchval']:"none"
$searchval2=(isset($_REQUEST['searchval2']))?$_REQUEST['searchval2']:"no
ne";
		if ($field <> "none") {
		  // Microsoft Access connection string.
		  // Douglas server
		  //$db =
'\\ms4w\\apps\\GeoMOOSE\\douglas\\maps_douglas\\database\\parcels.mdb';
		  // HEI server
		  $db =
'\\ms4w\\apps\\GeoMOOSE\\douglas\\maps_douglas\\database\\aex.mdb';
		  $conn = new COM('ADODB.Connection'); // or
exit('Cannot start ADO.');
		  // Two ways to connect. Choose one.
		  $conn->Open("Provider=Microsoft.Jet.OLEDB.4.0; Data
Source=$db"); // or exit('Cannot open with Jet.');
		  //$conn->Open("DRIVER={Microsoft Access Driver
(*.mdb)}; DBQ=$db"); // or exit('Cannot open with driver.');
		  // SQL statement to build recordset.
		  if ($field == "TRS" || $field2 == "DOCTYPE") {
		    $rs = $conn->Execute("SELECT * FROM
Surveyor_Image_Link WHERE TRS LIKE '%".$searchval."%' ORDER BY ".$sort."
ASC");
		//  ) elseif ($field2 == "DOCTYPE") {
		//    $rs = $conn->Execute("SELECT * FROM
Surveyor_Image_Link WHERE DOCTYPE LIKE '".$searchval2."%' ORDER BY
".$sort." ASC");
		  } else {
		    echo "You have reached this page by mistake.";
			Sent: Thursday, August 19, 2010 1:05 PM
			To: Jim Dahl;
			Good news, GM2.2 can do this! :) Bad news...
GM1.6 is harder and you need to use manual SQL.
			$clauses = array();
			if($field == "TRS") {
			 array_push($clauses, "TRS like
'%".$searchval$."%'");
			if($field2 == "DOCTYPE") {
			 array_push($clauses, "DOCTYPE LIKE
'".$searchval2."%'");
			$all_clauses = implode(" or ", $clauses);
Surveyor_Image_Link WHERE ".$all_clauses." ORDER BY ".$sort." ASC");
<jim.dahl at mail.co.douglas.mn.us>
				To: geomoose-users at lists.sourceforge.net
				Sent: Thu, August 19, 2010 9:56:08 AM
				Subject: [Geomoose-users] Need help with
				I am trying to add two search fields in
my GM app.  I can make each field search correctly by themselves but not
together.  I have the code where the first two lines work and when I
comment out the first two and enable the second two lines, the code
works for searchval2.  What I want to know is how can I use ELSE with or
without the OR statements to allow me to enable both fields for the
search?
				  if ($field == "TRS") {
ASC");
				//  ) if ($field2 == "DOCTYPE") {
FROM Surveyor_Image_Link WHERE DOCTYPE LIKE '".$searchval2."%' ORDER BY
".$sort." ASC");
				  } else {
mistake.";
				Jim Dahl, GISP
				GIS Coordinator
				Douglas County Public Works
				526 Willow Dr
				PO Box 398
				Alexandria MN 56308
				V 320-762-2933
				   320-762-2999
				F 320-762-2998
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100820/d12e27f8/attachment.html
More information about the Geomoose-users mailing list
