[Geomoose-users] no image in print
Dan Little danlittle at yahoo.com
Fri Feb 5 10:26:13 EST 2010
The problem is how your server is "referring" to itself.
If you log into the server, and try and access GeoMOOSE, what address do you need to use?
>From: FRANZ OKYERE <franzzoa at hotmail.com>
>To: geomoose-users at lists.sourceforge.net
>Sent: Fri, February 5, 2010 6:35:53 AM
>Subject: Re: [Geomoose-users] no image in print
> Please if you say you put the port number in the settings.ini do you mean as in www.myghanasearch.com:8080/...? I still don't get the map to print. Franz.
>________________________________
>To: danlittle at yahoo.com; franzzoa at hotmail.com; geomoose-users at lists.sourceforge.net
>Date: Wed, 3 Feb 2010 10:42:30 -0600
>Subject: RE: [Geomoose-users] no image in print
>I fixed my problem by putting the port for the apache server in
>the settings.ini in the localhost.
>Thanks
>jim
>From:Dan Little
>[mailto:danlittle at yahoo.com]
>Sent: Wednesday, February 03, 2010 10:40 AM
>To: FRANZ OKYERE; geomoose-users at lists.sourceforge.net
>Change
>mapserver_url to /cgi-sys/mapserv ... it's expecting a relative path.
>>From:FRANZ OKYERE <franzzoa at hotmail.com>
>>Sent: Wed, February 3, 2010 10:36:08 AM
>>>>Hi I am also not seeing any image for when I click on the print button. I have
>>checked settings.ini and mapbook for the trailing slashes and have read related
>>emails but I can't figure out what the source of the problem is. What else
>>could be wrong? Here is some inf. on the paths.
>><param name="mapserver_url">http://www.myghanasearch.com/cgi-sys/mapserv</param>
>>  <param name="mapfile_root">/home/myghanas/other/search/maps/</param>
>>Thanks in advance
>>>>Franz Okyere
>>>>GIS Specialist.
>>From: lkne at houstoneng.com
>>>>To: jhagedorn at bannerassociates.com; geomoose-users at lists.sourceforge.net
>>>>Date: Tue, 2 Feb 2010 17:26:49 -0600
>>Often when no images print
>>(but they are displaying correctly on-screen), the “root”  is not correct
>>in settings.ini.
>>Len
>>From:Jim Hagedorn
>>[mailto:jhagedorn at bannerassociates.com]
>>Sent: Tuesday, February 02, 2010 4:29 PM
>>Subject: [Geomoose-users] no image in print
>>Trying to get the print to work on my test site.  I
>>have looked at the other listings for anything with print problems and have not
>>been able to find a solution.  When I go to print all of the images are
>>blank.  I have used the print from the demo, but didn’t see anything that
>>needed to be changed to make mine to work.
>>Thanks
>>jim
>>Jim
>>Hagedorn
>>GIS
>>Specialist
>>Banner Associates, Inc.
>>409 22nd Avenue South· PO Box 298· Brookings, South Dakota 57006
>>(605) 692-6342 ·  Fax(605) 692-5714
>>www.bannerassociates.com
>>Do you want a Hotmail account? Sign-up now - Free
Do you have a story that started on Hotmail? Tell us now
Skipped content of type multipart/related
More information about the Geomoose-users mailing list
