[Geomoose-users] Printing not working on my remote host (GM 2.0)
Len Kne lkne at houstoneng.com
Tue Feb 16 10:11:22 EST 2010
Try updating print.php and print_util.php from trunk or the GeoMOOSE 2.2 download.  Then in settings.ini add the line:
server_name=www.myghanasearch.com
The server_name needs to be the FQN that the server will see itself as.  That is, if from the server you ping www.myghanasearch.com<http://www.myghanasearch.com>, it should resolve to the IP address of the server itself (not the IP address on the outside of the firewall).  This gets a little trickier if your site is on a hosted server behind a firewall with multiple sites on the server.  Hopefully this is not the case and it will work with the steps above.
Len
From: FRANZ OKYERE [mailto:franzzoa at hotmail.com]
Sent: Tuesday, February 16, 2010 8:40 AM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] Printing not working on my remote host (GM 2.0)
Hi All,
Please find attached the print.php, download.php, print_util.php and my settings.ini to see if you can figure out why I am able to print locally but  not able to print from the the website. I don't get any errors when I run getmapbook.php or run the www.myghanasearch.com/search/php/download.php.
Thanks.
Franz Okyere
GIS Specialist
Do you want a Hotmail account? Sign-up now - Free<http://clk.atdmt.com/UKM/go/197222280/direct/01/>
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100216/bec6032a/attachment.html
More information about the Geomoose-users mailing list
