[Geomoose-users] Printing not working on my remote host (GM 2.0)
FRANZ OKYERE franzzoa at hotmail.com
Thu Feb 18 01:49:21 EST 2010
I have tried you suggestion but I think you suspicion is rather true. The website is hosted on a shared server so I guess I will not be able to print! Any other suggestions- can I ask the host what the real IP address is instead of  the disguised ip infront of the firewall?
Thanks
Franz
To: franzzoa at hotmail.com; geomoose-users at lists.sourceforge.net
Date: Tue, 16 Feb 2010 09:11:22 -0600
Subject: RE: [Geomoose-users] Printing not working on my remote host (GM 2.0)
Try updating print.php and print_util.php from trunk or the GeoMOOSE 2.2 download.  Then in settings.ini add the line:
server_name=www.myghanasearch.com
The server_name needs to be the FQN that the server will see itself as.  That is, if from the server you ping www.myghanasearch.com, it should resolve to the IP address of the server itself (not the IP address on the outside of the firewall).  This gets a little trickier if your site is on a hosted server behind a firewall with multiple sites on the server.  Hopefully this is not the case and it will work with the steps above.
Len
From: FRANZ OKYERE [mailto:franzzoa at hotmail.com]
Sent: Tuesday, February 16, 2010 8:40 AM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] Printing not working on my remote host (GM 2.0)
Hi All,
Please find attached the print.php, download.php, print_util.php and my settings.ini to see if you can figure out why I am able to print locally but  not able to print from the the website. I don't get any errors when I run getmapbook.php or run the www.myghanasearch.com/search/php/download.php.
Thanks.
Franz Okyere
GIS Specialist
Do you want a Hotmail account? Sign-up now - Free
_________________________________________________________________
Tell us your greatest, weirdest and funniest Hotmail stories
http://clk.atdmt.com/UKM/go/195013117/direct/01/
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100218/02f49bec/attachment.html
More information about the Geomoose-users mailing list
