[Geomoose-users] List issue
Matthew D. Syvertson msyvertson at co.richland.nd.us
Thu Feb 18 10:25:31 EST 2010
Is anyone else having a problem where you get TWO of every email sent to
the list.  This just started, so I need to know if its just me...
Matt Syvertson
GIS Coordinator
Richland County, ND
msyvertson at co.richland.nd.us <mailto:msyvertson at co.richland.nd.us>
Sent: Thursday, February 18, 2010 9:23 AM
To: 'FRANZ OKYERE'; geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] Printing not working on my remote host (GM
2.0)
Hi Franz
You could try setting the server_name=localhost, this would be the same
as giving it the internal IP address.  This probably is not going to fix
the printing because:
Web hosting services generally host multiple websites on a single IP
address.  The web server looks at the header that is sent with the
request to determine which virtual website to send it to.  When opening
a page by IP address, the header contains the IP address as the server
name, and thus goes to the default website.
On our hosting server, we get around this by setting up a host entry
which points to the internal IP address.  For example:
internal-gm.houstoneng.com  192.168.1.1
Then in settings.ini, server_name=internal-gm.houstoneng.com, which
points the GeoMOOSE services to the correct internal IP address.  If
your service provider could add this entry, that will hopefully allow
printing.  Another diagnostic test is to make sure that WMS layers are
printing as they should not be affected by this setting.
Len
From: FRANZ OKYERE [mailto:franzzoa at hotmail.com]
Sent: Thursday, February 18, 2010 12:49 AM
To: Len Kne; geomoose-users at lists.sourceforge.net
Subject: RE: [Geomoose-users] Printing not working on my remote host (GM
2.0)
I have tried you suggestion but I think you suspicion is rather true.
The website is hosted on a shared server so I guess I will not be able
to print! Any other suggestions- can I ask the host what the real IP
address is instead of  the disguised ip infront of the firewall?
Thanks
Franz
To: franzzoa at hotmail.com; geomoose-users at lists.sourceforge.net
Date: Tue, 16 Feb 2010 09:11:22 -0600
2.0)
Try updating print.php and print_util.php from trunk or the GeoMOOSE 2.2
download.  Then in settings.ini add the line:
server_name=www.myghanasearch.com
The server_name needs to be the FQN that the server will see itself as.
That is, if from the server you ping www.myghanasearch.com
<http://www.myghanasearch.com/> , it should resolve to the IP address of
the server itself (not the IP address on the outside of the firewall).
This gets a little trickier if your site is on a hosted server behind a
firewall with multiple sites on the server.  Hopefully this is not the
case and it will work with the steps above.
Len
Sent: Tuesday, February 16, 2010 8:40 AM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] Printing not working on my remote host (GM
2.0)
Hi All,
Please find attached the print.php, download.php, print_util.php and my
settings.ini to see if you can figure out why I am able to print locally
but  not able to print from the the website. I don't get any errors when
I run getmapbook.php or run the
www.myghanasearch.com/search/php/download.php.
Thanks.
Franz Okyere
GIS Specialist
Do you want a Hotmail account? Sign-up now - Free
<http://clk.atdmt.com/UKM/go/197222280/direct/01/>
We want to hear all your funny, exciting and crazy Hotmail stories. Tell
us now <http://clk.atdmt.com/UKM/go/195013117/direct/01/>
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100218/215baf74/attachment.html
More information about the Geomoose-users mailing list
