[Geomoose-users] Geomoose optimization... map source
Bob Basques Bob.Basques at ci.stpaul.mn.us
Thu Feb 18 11:52:08 EST 2010
All,
Actually in the 1.x series of GeoMoose you could combine the layers into
a single image, but you don't have the end user controls available for
anything except turning the whole layer set (in geomoose) on/off, the
2.x series allows for single images as well as individual layer controls
inside of the single images.
bobb
>>> Len Kne <lkne at houstoneng.com> wrote:
Just to be clear, we are talking GM 2.x (in GM 1.x each source could be
only one layer).
For my two cents, I tried to put all layers into a single mapfile and
thus have one map-source, but generally don’t do this any more because:
1.
The stack order of layers is set by the order of the layers in the
map-source (top layer on top, then goes down from there)
2.
Opacity is set at the map-source level, thus all layers in a map-source
would have the same opacity
3.
The fade-in and fade-out tools work at the map-source level, thus all
layers would be changed when changing one in the catalog
4.
Tend to get a redraw of all layers in the map-source when turning one
layer on/off
I still combine “like” layers into one map-source and one mapfile, but
watch how the layers are going to be displayed.
Len
Mark Volz [mailto:MarkVolz at co.lyon.mn.us]
Sent: Thursday, February 18, 2010 8:46 AM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] Geomoose optimization... map source
Hello,
I would like to try to move all my layers into a single .map file so
that only
one map with many layers is drawn at a time.  Is the standard practice
to:
1)
Create a single <map-source> with
multiple references in the catalog to that single map source.
2)
Create
separate <map-source> tags that each have their own reference
to the same
.map file.
For example which example between the two is a standard practice so only
one map is drawn?
<map-source name="AllLayers" type="mapserver">
<file>AllLayers.map</file>
<layer name="layer1"/>
<layer name="layer2"/>
<layer name="layer3"/>
</map-source>
<catalog>
<layer title="layer1" src="AllLayers/layer1"/>
<layer title="layer2" src="AllLayers/layer2"/>
<layer title="layer3" src="AllLayers/layer3"/>
</catalog>
OR
<map-source name="layer1" type="mapserver">
</map-source>
<map-source name="layer2" type="mapserver">
</map-source>
<map-source name="layer3" type="mapserver">
</map-source>
<catalog>
<layer title="layer1" src="layer1/layer1"/>
<layer title="layer2" src="layer2/layer2"/>
<layer title="layer3" src="layer3/layer3"/>
</catalog>
Next,
Is it okay to use this method for operational layers such as parcels?
Thanks
Mark Volz
GIS Specialist
Lyon County, MN
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100218/c97a7728/attachment.html
More information about the Geomoose-users mailing list
