[Geomoose-users] Google layers, Web Mercator and Coordinates shift
Brent Fraser bfraser at geoanalytic.com
Fri Feb 19 10:20:56 EST 2010
The great thing about the EPSG system is that you can add coordinate system
definitions as you need them.
You can use the OpenLayer's code for Spherical Mercator and add it to your
proj/nad/epsg file:
# Google / OpenLayers
<900913> +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0
+k=1.0 +units=m +nadgrids=@null +no_defs
Or you can wait for the various software groups to get updated to the new EPSG
definitions which include the "official" code of 3785.
Here are some links for more info:
http://www.sharpgis.net/post/2008/05/SphericalWeb-Mercator-EPSG-code-3785.aspx
http://spatialreference.org/ref/sr-org/6/
http://docs.openlayers.org/library/spherical_mercator.html
Best Regards,
Brent Fraser
FRANZ OKYERE wrote:
> Hi all,
> I have mangaged to display the google layers under my other layers fine
> but it seems there is a shift. I guess, naturally, the coordinates used
> as for the extents and the map layers have to conform to the 'google's
> projection'. The little reading I have done, and googling around, tells
> me that google's projection is not standard- i.e. EPSG just decided to
> add it on their list.
> Does anyone have a work around- say, a way to do the reprojection? What
> software would you go for and what are the issues? Thanks.
> /Franz Okyere/
> GIS Specialist
More information about the Geomoose-users mailing list
